Electric potential energy - how is it conserved?
The discussion revolves around the conservation of electric potential energy in a system of two charged particles. The original poster presents a scenario involving two particles with given masses and charges, initially held in place and then released, leading to a question about the initial separation between them based on their speeds after separation.
  • The original poster attempts to apply conservation of energy principles but expresses confusion about the correct formulation of the energy equation and the implications of their results. They question whether their approach accounts for both particles' energies and how to handle multiple unknowns.
  • Some participants suggest considering the conservation of momentum alongside energy conservation to establish a relationship between the velocities of the two particles.
  • Others question the setup of the energy equation, particularly the use of the separation distance in the denominators and whether the energy conservation should focus solely on one particle.
The discussion is ongoing, with participants exploring different interpretations of energy and momentum conservation. Some guidance has been offered regarding the relationship between momentum and energy conservation, but no consensus has been reached on the correct approach to the problem.
There is a noted complexity in solving for two unknowns (initial separation and the velocity of the second particle) and a concern about the implications of focusing on only one particle's energy in the context of the overall system.
vaxopy
obviously the answer is yes , its conserved.. but something bugs me about it.
One particle has a mass of 3.00×10–3 kg and a charge of +8.00 mC. A second particle has a mass of 6.00×10–3 kg and the same charge. The two particles are initially held in place and then released. The particles fly apart, and when the separation between them is 0.100 m, the speed of the 3.00×10–3-kg particle is 125 m/s. Find the initial separation between the particles.
Am i doing this correctly?
Ebefore = Eafter
kq1q2/r = kq1q2/(r+0.1) + m1v1^2/2
is this correct? if so, does that mean (according the the equation) all the energy is in the 1st particle.. then the other one should be stationary? obviously not.. then why is my equation wrong? what am i missing?
should it be
kq1q2/r = kq1q2/(r+0.1) + m1v1^2/2 + m2v2^2/2 ?
but now how can u solve for 2 unknowns? (r and v2) would you use m1v1 = m2v2 to solve for v2? why (if u can) can u use this?
Energy is only conserved in an inertial reference frame. That is to say, energy is only conserved if momentum is too. So you need to pick a frame where the total momentum of the system (or the velocity of the center of mass) is the same before and after, then apply conservation of energy. The conservation of momentum condition will give you a relation between v1 and v2 and then the conservation of energy condition allows you to solve for them.
im so confused :'(
is what I am doing correct?
Ebefore = Eafter
should it be
Why is there an (r + 0.1) in one of the denominators ? Just use "0.1" as the final distance of separation.
You're only dealing with conservation of energy as applied to the less massive particle. The work done on that particle by the repulsive electrostatic force is equal to the change in its kinetic energy. So you don't have to "worry" about the other particle at all.
You just have to make sure that whatever v1 and v2 are, momentum is conserved, as you mentioned at the end of your post. The reason for this is that conservation of energy only holds if conservation of momentum is holding as well.
  • · Replies 22 ·
  • · Replies 23 ·
