Elastic Collisions: billiard ball problem with a twist
The problem involves an elastic collision between two billiard balls, where one ball is initially in motion and the other is stationary. The first ball has a mass of 10 kg and an initial velocity of 5 m/s, while the second ball has a mass of 5 kg. After the collision, the first ball moves at a 30-degree angle above the x-axis, and the second ball moves at a 45-degree angle below the x-axis. The task is to calculate the final velocities of both balls using principles of conservation of momentum and kinetic energy.
  • Mixed
  • The original poster attempts to determine whether it is necessary to use the kinetic energy equation in addition to the momentum equations, given the angles of deflection provided. They express confusion about solving for two unknowns with three equations.
  • Some participants suggest that conservation of momentum alone may suffice, given the information available.
  • Others note that the problem may be an example of an overdetermined system, where the number of equations exceeds the number of unknowns.
  • One participant raises a concern about the total energy after the collision exceeding the initial kinetic energy, questioning the feasibility of the given angles.
The discussion is ongoing, with participants exploring the implications of using only momentum conservation versus incorporating kinetic energy. There is no explicit consensus on the necessity of the kinetic energy equation, but some guidance has been offered regarding the sufficiency of momentum equations based on the provided angles.
Participants are considering the implications of the angles given for the balls after the collision and how they relate to the conservation laws. There is a noted discrepancy in energy calculations that may affect the validity of the proposed angles.
Benny851
A billiard ball ( mass = 10kg, initial velocity is 5 m/s) is launched along x-axis at a stationary billiard ball ( mass = 5kg). After collision, the first ball goes off at 30 degree angle above x-axis and 2nd ball goes off at 45 degree angle below x-axis. Calculate the final velocities of both billiard balls.
M1V1 + M2V2 = M1V1final + M2V2final (conservation of momentum)
1/2M1V1^2 + 1/2M2V2^2 = 1/2M1V1final + 1/2M2V2^2
Typically in most billiard ball problems you are not given both angle measurements, which means you need 3 equations: momentum in x direction, momentum in y direction and Kinetic energy. But, in this case I only have 2 unknowns, not 3. So my question is whether I need to even use the third kinetic energy equation? I don't understand how I can solve for 2 unknowns by using 3 equations. My gut tells me just to use the 2 momentum equations, which is what I have been doing, but whenever I read about elastic collision problems I see that KE equation is also used. Some guidance on this topic would be really appreciated. Thanks.
Momentum is always conserved, so if here is enough information given to solve the problem using only conservation of momentum, go for it!
Your reasoning is correct, there's no need for the kinetic energy equations precisely because you know the angles they went off on. It's really just a way to test your understanding, to make sure you appreciate the underlying concept (conservation of linear momentum) by changing the usual form of the question. Mathematically, it's an example of what's sometimes called an overdetermined system (more equations than unknowns). Of course, once you know the final velocities you can then go ahead and calculate the kinetic energies, if you wished.
The initial kinetic energy is 125 J. When I work out the final speeds of the two balls using conservation of momentum, the total energy is a bit more than 125 J. So the directions given for the balls after the collision is not quite possible.
AM
  • · Replies 41 ·
  • · Replies 16 ·
