Sx acting on up spin particle confusion
The discussion revolves around the interpretation of measuring the x component of spin for a spin-up particle, particularly in the context of quantum mechanics. Participants explore the implications of measurement, the relationship between different spin states, and the mathematical operations involved in such measurements.
  • One participant expresses confusion about measuring the x component of spin on a spin-up particle, questioning why the result appears to yield a spin-down state in the z direction.
  • Another participant clarifies that measuring the x component involves projecting the spin-up state onto the eigenstates of the Sx operator, suggesting that the Sx operator acts as a stepping operator.
  • A subsequent post proposes a method for measuring the x component by expressing the spin-up state as a linear combination of Sx's eigenvectors before applying the Sx operator.
  • Another participant emphasizes the need to define the up and down states with respect to the x-axis before proceeding with measurements.
  • One participant questions the application of the Sx operator to the spin-up state, indicating a potential misunderstanding of the measurement process.
  • A later reply discusses the probabilistic nature of quantum measurements, stating that one can only predict probabilities rather than obtaining definitive results from operations on state vectors.
Participants exhibit a range of views regarding the interpretation of measurements and the application of operators in quantum mechanics. There is no consensus on the correct approach to measuring the x component of spin or the implications of such measurements.
Some limitations in the discussion include the dependence on definitions of spin states, the probabilistic nature of quantum measurements, and the unresolved mathematical steps involved in projecting states onto eigenvectors.
DocZaius
I am reading Griffiths and I am having trouble interpreting the results of measuring the x component of spin on a spin-up particle.
If you have a spin up particle, my understanding is that it is assumed to be up in the preferred axis, z. I would think that measuring its x component should give half probability of h-bar/2 and half of negative h-bar/2. But what I get is h-bar/2 times spin down (down in z axis right?):
[itex]Sx\uparrow=\frac{\hbar}{2}<br /> \left( \begin{array}{ccc}<br /> 0 & 1 \\<br /> 1 & 0 \end{array} \right)<br /> \left( \begin{array}{ccc}<br /> 1 \\<br /> 0 \end{array} \right)<br /> =\frac{\hbar}{2}\downarrow[/itex]
I don't see why this would make any sense. You measure the x component of the spin of a spin-up particle and get h-bar over 2 times spin down? Does that mean the particle is now spin down on the z axis? Shouldn't it be on the x-axis now that we measured it in respect to the x component?
Also, just to be clear: the generic spin-up spinor without a (z) superscript implies it is a spinor of the z axis right?
[itex]X=X^{(z)}[/itex] ?
You didn't measure anything. Applied to eigenstates of Sz, the Sx operator acts as a stepping operator (it's equal to ½(S+ + S-)) The S+ gives zero, and the S- steps you down. So no wonder you got the spin down state!: wink:
What you want to do is find the overlap between the spin up state and the eigenstates of Sx. This will give you the probability amplitude of measuring each value of Sx. From the matrix you wrote, the eigenstates of Sx are (1/√2)(1, ±1).
So if I wish to measure the x component of the spin-up particle, I first project spin-up onto Sx's eigenvectors, thereby expressing it as a linear combination of them, then Sx that vector?
1) V = <Sx's first eigenvector|Spin up vector> (Sx's first eigenvector) + <Sx's second eigenvector|Spin up vector> (Sx's secondeigenvector)
2) (Sx)V
Is that right?
yes,you will have to first define up and down with respect to x axis.
?? why would you apply the spinx operator to spin up state
One cannot make a measurement in quantum mechanics. One can only predict probabilities for numerous measurements. There is no mathematical operation as we know it now that one can use in quantum mechanics were one applies something to a state vector, and gets back a result. This can't happen since the results are random, and you never hit a state vector with something and get a random result back. You can calculate the probability of obtaining a result in a lab where you do an actual mesearment. For your case it would be [itex]\langle \uparrow_{x}|\uparrow_{z}\rangle[/itex] or something like that depending what you want to know.
  • · Replies 42 ·
