Nxmod(1) is a discrete subset of [0,1] iff x is a rational?
  • Thread starter Thread starter Silversonic
    Discrete Rational
The discussion revolves around the properties of the set defined by \( n\theta \mod(1) \) for \( \theta \in [0,1] \) and \( n \in \mathbb{Z} \). Participants are tasked with showing that this set is discrete if and only if \( \theta \) is rational.
  • Mixed
  • Participants explore the "only if" part of the statement, questioning how to demonstrate that if the set is discrete, then \( \theta \) must be irrational. They discuss the implications of the set being infinite and the potential for a surjective map to contradict discreteness.
There is ongoing exploration of the relationship between the discreteness of the set and the rationality of \( \theta \). Some participants suggest that compactness and the existence of limit points in the interval [0,1] may be relevant, while others seek alternative approaches to the proof.
Participants note that the problem may involve concepts from metric spaces and compactness, which some have not previously encountered. There is also mention of the problem being labeled as "easy," which has led to some confusion regarding the complexity of the proof.
Silversonic
Let [itex]\theta \in [0,1][/itex] and [itex]n \in \mathbb{Z}[/itex]. Let [itex]n\theta mod(1)[/itex] denote [itex]n\theta[/itex] minus the integer part. Show [itex]n \theta mod(1)[/itex] is a discrete subset of [0,1] if and only if theta is rational.
I'm having a bit of trouble with the "only if" part of the statement. The "if" part of the statement is simple. If theta is rational, then the subset is finite (because [itex]n \theta mod(1)[/itex] will repeat itself once [itex]n[/itex] is equal to or larger than [itex]p[/itex], where [itex]\theta = q/p[/itex]). Since it is a finite subset, it is discrete.
But the only if part? Assume that it is a discrete subset, I need to show this is irrational. I'm having trouble with that. If I could show there was a surjective map from [itex]n\theta mod(1)[/itex], theta being irrational, to the subset [0,1] then that would prove it. Since no point would be isolated in that case, and the set wouldn't be discrete. I can't seem to get anywhere with that, though.
I know that [itex]n \theta mod (1)[/itex], for theta irrational, is an infinite set (not that this proves discreteness), so maybe I could go from there? It's infinite, because if it were not, then we would have that [itex]k\theta mod(1)[/itex] and [itex]n\theta mod (1)[/itex] would be mapped on to the same number, for different integers k and n.
i.e.
[itex]k\theta = p + r[/itex]
[itex]n\theta = q + r[/itex]
p,q are integers and r is the "remainder part".
equating shows
[itex]\theta = (p-q)/(k-n)[/itex]
Contradicting irrationality.
Maybe I could go somewhere with that fact that it's an infinite set? I haven't managed to though.
i.e.
equating shows
Do you know that [0,1] is compact? If you have an infinite number of points there must be a limit point.
Checking wikipedia quickly, "If one chooses an infinite number of distinct points in the unit interval, then there must be some accumulation point in that interval". I guess that would prove it. Compactness is not something I've dealt with before (I think it's relevant to metric spaces, a module I did not choose). The fact that my notes said this was meant to be an "easy proof" threw me off a bit though, it didn't seem like it would take such a result in order to prove it.
Is there any other way? If not, thanks. That will do.
easy proof throw me off a bit though, it didn't seem like it would take such a result in order to prove it.
There's a less abstract way. Take any N>0. Divide [0,1] up into N intervals of length 1/N. Since there are an infinite number of points there must be an interval [k/N,(k+1)/N] that contains at least two points. Think about their difference. It's less that 1/N, right? So?
  • · Replies 16 ·
