What is the dimension of eigenspaces in a function-based linear transformation?
  • Context: Graduate
  • Thread starter Thread starter Tala.S
    Dimension
The discussion focuses on determining the dimension of eigenspaces in the context of the linear transformation f: C^∞(R) -> C^∞(R), defined by f(x(t)) = x'(t). The eigenvalue problem is set up with eigenvalues λ = -5 and λ = 0, leading to the eigenspaces E-5 = ke^-5t and E0 = k. It is concluded that each eigenspace is one-dimensional, as every solution can be expressed as a constant multiplied by the exponential function e^{\lambda t}.
  • Understanding of linear transformations in functional spaces
  • Familiarity with eigenvalues and eigenspaces
  • Knowledge of exponential functions and their properties
  • Basic concepts of differential equations
  • Study the properties of linear transformations in functional analysis
  • Learn about the spectral theorem for linear operators
  • Explore the concept of eigenfunctions in the context of differential equations
  • Investigate the implications of one-dimensional eigenspaces in various applications
Mathematicians, physicists, and students studying linear algebra and differential equations, particularly those interested in functional analysis and eigenvalue problems.
Tala.S
Linear transformation f:C^∞(R) -> C^∞(R)
f(x(t)) = x'(t) a) I have to set up the eigenvalue-problem and solve it :
My solution : ke^λtb) Now I have to find the dimension of the single eigen spaces when λ is
-5 and 0. My solution :
Eigenspaces :
E-5 = ke^-5t
E0=k (because ke^0t = k)
But I don't know how to find the dimension of the single eigen spaces ?
I'm used to working with vectors but now it's functions and I'm not sure about the dimension.
Solved !
Good! I presume that you realized that since every solution, [itex]Ce^{\lambda x}[/itex] is a constant, C, times the single function [itex]e^{\lambda x}[/itex], the space is one dimensional.
