How Does a Pendulum Reveal Bus Acceleration in Different Reference Frames?
The discussion centers on how a pendulum can be used to determine the acceleration of a bus moving parallel to the Earth's surface. In an inertial reference frame, the relationship between the angle of the pendulum and the bus's acceleration is given by the equation a = g tan A, where A is the angle and g is the acceleration due to gravity. In contrast, in the noninertial reference frame of the bus, the pendulum appears stationary, leading to the erroneous conclusion that A = 0. This discrepancy arises from the presence of fictitious forces in noninertial frames, which must be accounted for in calculations.
  • Understanding of Newton's laws of motion
  • Familiarity with inertial and noninertial reference frames
  • Basic knowledge of forces, including tension and gravity
  • Concept of fictitious forces in physics
  • Study the effects of fictitious forces in noninertial reference frames
  • Learn about the principles of pendulum motion and its applications
  • Explore the concept of acceleration in different reference frames
  • Investigate methods for measuring acceleration in noninertial systems
Physics students, educators, and anyone interested in understanding the dynamics of motion in different reference frames, particularly in relation to acceleration and forces.
StephenPrivitera
Suppose we are on a windowless bus that travels parallel to the Earth's surface at a constant acceleration with respect to the Earth's surface. How can a passenger in the bus determine the acceleration of the bus?
We decided we could attach a mass to a string and attach the string to the ceiling. From inside the bus, it would look like this:
________________
...O
Ignore those dots. Theyre the only way I can space things over.
There are two forces acting on this mass: gravity and the tension of the string. From the Earth's referece frame, the mass is accelerating with the same acceleration as the bus, ie, horizontally. So the only force the causes the mass to accelerate is TsinA=ma where T is the tension is the string, A is the angle measured wrt the line perpendicular to the ceiling, and a is the acceleration of the bus (and ball). Also, TcosA-mg=0 since there is no acceleration in this direction. Dividing each by each yields a=gtanA.
From the reference frame of the bus, the mass is stationary. TsinA=0 and TcosA=mg. Dividing each by each yields 0=tanA or A=0. Does this spurious result come from the fact that the reference frames are noninertial with repsect to each other? How come the result is valid for one frame but not the other?
Yes, with respect to the bus, you cannot say that TsinA=0 because the bus is an accelerating frame of reference. You must include this acceleration in any calculations that you make.
The principle of invariance only applies to inertial (non accelerating) frames of reference.
Claude.
Yes, the spurious result comes from the fact that the reference frames are noninertial with respect to each other. In a noninertial reference frame, fictitious forces, such as the centrifugal force or the Coriolis force, may appear to act on objects. These forces are not real, but rather a result of the frame's acceleration. In this case, the fictitious force is the "centrifugal" force that appears to act on the mass attached to the string.
In the Earth's reference frame, the mass is accelerating horizontally due to the acceleration of the bus. This acceleration is counteracted by the tension in the string, resulting in the equation a=gtanA. However, in the reference frame of the bus, the mass is stationary and there is no acceleration. Therefore, the tension in the string is equal to the weight of the mass, resulting in the equation A=0. This difference in results is due to the presence of the fictitious force in the noninertial reference frame.
It is important to note that the acceleration of the bus can still be determined by the passenger using other methods, such as measuring the change in speed or observing the motion of objects outside the bus. However, the method described using the mass attached to a string will only yield accurate results in an inertial reference frame. In a noninertial reference frame, the results will be affected by the presence of fictitious forces.
  • · Replies 19 ·
