Simple first-order series solution
The discussion focuses on solving the differential equation y' - xy = 0 using series solutions. The proposed solution involves expressing y as a power series y = Ʃ from 0 to infinity a_n x^n and deriving a recurrence relation. The relation yields a1 = 0 and (k+1)a_(k+1) - a_(k-1) = 0, leading to a pattern where all coefficients a_n for odd n are zero, while even coefficients can be expressed in terms of a0. The solution demonstrates a systematic approach to finding coefficients and hints at a factorial relationship in the denominators of even-indexed terms.
  • Understanding of first-order differential equations
  • Familiarity with power series and their convergence
  • Knowledge of recurrence relations and their applications
  • Basic principles of mathematical induction
  • Explore the derivation of power series solutions for different types of differential equations
  • Learn about the convergence criteria for power series
  • Investigate the role of factorials in series expansions and their implications
  • Study mathematical induction techniques for proving properties of series
Students and educators in mathematics, particularly those studying differential equations and series solutions, as well as researchers looking for systematic methods in solving similar mathematical problems.
th3chemist
The question is y' - xy = 0
I have to solve it using series solutions
I use y = Ʃ from 0 to infinity a_n x^n and took the derivative. I plugged it into the equation
I got the recurrence relation to be a1 = 0 and (k+1)a_(k+1) - a_(k-1) = 0
Assuming that your work is correct (can't tell because you don't show it), then consider a0 to be arbitrary, and find a2 in terms of a0. a3 will be zero because a1 is. Continue finding a4, a6, and so on, in terms of a0.
That is, if [itex]a_0[/itex] is the inital value, taking k= 1, [itex]2a_2= a_0[/itex] so [itex]a_2= a_0/2[/itex]. Then taking k= 2 [itex]3a_3= a_1= 0[/itex] so [itex]a_3= 0[/itex]. Taking k= 3, [itex]4a_4= a_2= a_0/2[/itex] so [itex]a_4= a_0/8[/itex]. Taking k= 4, [itex]5a_5= a_3= 0[/itex] so [itex]a_5= 0[/itex]. Taking k= 5, [itex]6a_6= a_4= a_0/8[/itex] so [itex]a_6= a_0/48[/itex], etc.
It should be obvious that [itex]a_n= 0[/itex] for all odd n (and you should be able to prove it by induction on n) while for n even we get [itex]a_0[/itex] over 2, 8, 48, ... Continue for a few more terms to see if you can find a formula for those denominators. It shouldn't surprise you if it involves a factorial.
