| New Reply |
nitrogen molecules in air question |
Share Thread | Thread Tools |
| Dec9-12, 02:54 PM | #1 |
hi all. i'm trying to write an article about a molecular perspective on (aircraft) lift. im guessing nitrogen does most of the lift since it's the most abundent in air. how does a nitrogen molecule stick to a steel molecule (plane's)? is there a short term electronic bond between the two molecules? thanks guys
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Dec9-12, 08:55 PM | #2 |
How do you think airplanes fly?
| Dec10-12, 10:11 AM | #3 |
There a few threads around here about how airplanes fly. I would suggest you read a few of them and then repostulate your initial assumptions on what creates lift. Why do you assume that they atmosphere and the wing has to stay together?
| Dec10-12, 12:36 PM | #4 |
Recognitions:
Since the air is flowing around the wing during flight, perhaps there is very little sticking going on.
| Dec13-12, 02:19 AM | #5 |
| Dec16-12, 08:00 AM | #6 |
scumhearted,
Ratch P.S. In English, first words of sentences are capitalized. That makes sentences much easier to read. |
| Dec16-12, 09:37 AM | #7 |
Thanks a lot! Cheers! |
| Jan15-13, 01:14 AM | #8 |
| Jan15-13, 01:16 AM | #9 |
also, you can't deny the molecular structure of things. just because we live day to day on a macroscopic world, and base our lives on it, you can't deny the fundamentals of everything |
| Jan15-13, 07:49 AM | #10 |
Mentor
No one is denying anything here. The question here is whether it is RELEVANT or not to the phenomenon! I'm sure when you do your many calculations, you ignore the gravitational field from Alpha Centauri, don't you? Do you think leaving out such a thing affects the accuracy of many of the things you do or calculate? Do not go into this line of discussion until you have done a considerable reading on "emergent phenomena". Zz. |
| Jan15-13, 07:55 AM | #11 |
| Jan15-13, 10:36 AM | #12 |
Mentor
Zz. |
| Jan15-13, 02:29 PM | #13 |
Mentor
Nope. It's wrong. The Coanda effect is an aerodynamic phenomena, not a chemical phenomena.
| Jan15-13, 03:04 PM | #14 |
Molecular effects are responsible for the Prandl layer aka as no slip condition I suppose. http://en.wikipedia.org/wiki/No-slip_condition Exactly how it works is not important, maybe it's van der Waals, surface roughness, general adhesion, ... relative flow will be very close to zero on the first few layers of molecules. It doesn't really matter if it is not perfectly zero. Changing the surface material of an air plane by coating does not have an effect on flight characteristics afaik. Also the gas doesn't matter. All surfaces make all gases flow slow enough to be approximated by zero relative velocity.
| Jan15-13, 03:42 PM | #15 |
Recognitions:
Viscosity is also a factor. If visocity is near zero, then adjacent streams of different speeds can flow by each other with almost no interaction, so the "void" could be filled with a stagnant very low visocity gas with almost no movment of that gas, and the stagnant gas would behave as if it were part of the airfoil. |
| New Reply |
| Thread Tools | |
Similar Threads for: nitrogen molecules in air question
| Liquid Nitrogen Question | Materials & Chemical Engineering | 2 | ||
| Is neutral nitrogen the same as N2 (nitrogen gas)? | Atomic, Solid State, Comp. Physics | 2 | ||
| Thermodynamics question. In Dewar flask liquid nitrogen. | Advanced Physics Homework | 1 | ||
| Do high power microwaves ionise water molecules and/or rearrange food molecules? | General Discussion | 10 | ||
| *May be a stupid question* Does Oxygen/Nitrogen bend space-time? | Special & General Relativity | 3 | ||
