Is the Lowest Possible Spin of Particle p 2 in Decay Scenarios?
  • Context: Graduate
  • Thread starter Thread starter MarkovMarakov
    Particle
The discussion centers on the decay scenarios of a particle p, which can decay into either a spin-1 particle and a spin-0 particle or two spin-0 particles. The conclusion drawn is that the lowest possible spin of particle p is 2, as it must be even and sufficiently large to accommodate the spin-1 product. The argument is based on the conservation of total angular momentum and parity during the decay process. Additionally, the intrinsic parity of particle p is questioned, with the assumption that it may be negative due to the negative intrinsic parities of the decay products, ρ+ and π-.
  • Understanding of particle spin and angular momentum conservation
  • Familiarity with intrinsic parity in particle physics
  • Knowledge of decay processes in quantum mechanics
  • Basic concepts of particle classification (spin-0, spin-1)
  • Research the principles of angular momentum conservation in particle decay
  • Study the implications of intrinsic parity in particle interactions
  • Explore decay channels of particles with varying spins
  • Learn about the classification of particles based on spin and parity
Particle physicists, quantum mechanics students, and researchers interested in decay processes and angular momentum conservation in particle interactions.
MarkovMarakov
Does the following argument correct?
Suppose there is a particle $p$ that can either decay into $ \{$a spin-1 and a spin-0 particle$\}$ or two spin-0 particles, then the lowest possible spin of $p$ is 2. This is because we need the spin to be even and large enough to accommodate the spin-1 product.
(Assuming that the total ang momentum is conserved in the decay.)
Thank you in advance!
ADDED:
[itex]p[/itex] is such that [itex]p\to \pi^-+\rho^+[/itex] and [itex]p\to \xi+\xi[/itex] where [itex]\xi[/itex] is a particle of spin 0. I want to know the lowest possible spin for [itex]p[/itex].
I am assuming that conservation of total angular momentum and parity holds.
By the way, would the intrinsic parity of [itex]p[/itex] be negative, since I think each of [itex]\rho^+[/itex] and [itex]\pi^-[/itex] have negative intrinsic parity?
  • · Replies 20 ·
  • · Replies 99 ·
