Maximum distance between things connected to a point (3D trig)
  • Context: Undergrad
  • Thread starter Thread starter ShawnD
    Maximum Point Trig
The discussion revolves around determining the angles between the edges of a cube and a rope attached to one of its corners. Participants explore the geometric and trigonometric implications of this setup, considering both 2D and 3D perspectives. The conversation includes various approaches to calculating these angles and the relationships between them.
  • One participant proposes a method to calculate the angle between the edges of the cube and the rope, suggesting an average of angles based on a 2D perspective.
  • Another participant provides a solution using trigonometric relationships, defining the angles in terms of a unit cube and deriving the angle using sine functions.
  • A third participant introduces the Pythagorean identity for cosines, suggesting a different approach to find the angle based on the symmetry of the cube's diagonal.
  • There is acknowledgment of the second participant's method as an improvement over the initial proposal.
Participants present multiple approaches to the problem, with no consensus on a single method or solution. Different angles and calculations are proposed, indicating ongoing exploration and debate.
Participants rely on various assumptions about the geometry of the cube and the nature of the angles involved, with some methods depending on specific definitions of the cube's dimensions and orientations.
Individuals interested in geometric relationships, trigonometry, and mathematical reasoning related to three-dimensional shapes may find this discussion relevant.
ShawnD
I'm not exactly sure if this is a trig type thing. It just really seems like it.
Suppose you attach a rope to the corner of a cube then suspend the cube. What will the angle be between the edges of the cube and the rope?
If I hold a rubik's cube in my hand in a 2D perspective as just a square, the angle between the edges is 90 degrees, and the angle between either edge and where the rope would be should be the same. I would be able to say 2x + 90 = 360, x = 135 degrees. I can say that for all 3 ways of looking at that single corner of the cube (each corner has 3 adjacent planes). I can then draw 3 angles out from those 3 planes.
What I want to know is how I can average those out or tie them together or something of that nature.
Why was this moved to physics? It has essentially nothing to do with physics.
Look, what you want to know, is not clear to me, but if you want to know the angle between any edge and the rope (which may not be the situation since you seem to have a solution for it), then I can give a solution.
Let the point of suspension be O and let the three edges be OA, OB and OC. Also, let the required angle be a.(Of course, the angle that OA makes with the rope = angle that OB makes with the rope and so on) Also, let the cube be a unit cube. Don't let anything else.
Produce the line along the rope downward to intersect the equilateral triangle ABC in G.
From simple trigonometry, GA = GB = GC = sin(a)
Also, since OA, OB, OC are mutually perpendicular, AB = BC = CA = square root of 2. (Pythagoras theorem)
Again, from simple trigonometry in triangle ABC, AB/sin(60 degrees) = 2 * GA = sin(a)
So, sin(a) = sqrt(2/3) And so a = arcsin (sqrt(2/3)), not 135.
Thank you very much. You've been a tremendous help.
Use the Pythagorean identity for cosines. For however many axes you have (2, 3, etc), if you measure the angle from a vector to each of the axes, the sum of the square of those cosines equals 1.
In other words, if you have 2 axes (2-D) and the angle between the vector and the x-axis is α, and the angle between the vector and the y-axis is β, then:
[tex]cos^2 \alpha + cos^2 \beta = 1[/tex]
With 3 axis and adding the angle γ for the angle between the vector and the z-axis, the Pythagorean identity becomes:
[tex]cos^2 \alpha + cos^2 \beta + cos^2 \gamma = 1[/tex]
Since all three angles will be the same for the diagonal of a cube, your angle is:
[tex]cos^{-1} (\sqrt{\frac{1}{3}})[/tex]
Oh, yes, that's a better way of doing it. Nice, bobG...
  • · Replies 24 ·
  • · Replies 26 ·
