Work done through linear expansion
To calculate the work done by the aluminum flagpole during linear expansion, the formula w = PΔV is used, where P is the pressure and ΔV is the change in volume. The initial volume at 10°C is determined using the mass and density of aluminum, resulting in approximately 2.963 m³. The flagpole expands by 0.024 m due to a temperature increase from 10°C to 20°C, which affects its volume. The coefficient of volume expansion, related to the linear expansion coefficient, is necessary for finding the final volume at 20°C. The expected answer for the work done is 213 J, highlighting the importance of understanding volume expansion in this context.
LadyMario
An 8000kg aluminum flagpole 100m long is heated by the sun from a temperature of 10°C to 20°C. Find the work done (in J) by the aluminum if the linear expansion coefficient is 24*10-6 /°C. (The density of aluminum is 2.7*103 kg/m3 and 1 atm = 1.0*105 N/m2)
I know w=PΔV, and I know V at 10°C = mass/density= 8000/2.7*103 = 2.963m3
I know how much longer the flagpole grows: ΔL=αLΔT = 24*10-6(100)(20-10)=0.024m
But how does the volume at 20°C relate to the growth of the flagpole through linear expansion?
The answer is suppsoed to be 213 J.
Do you know the formula for volume expansion? The coefficient of volume expansion has a simple relation to the coefficient of linear expansion.
Yea I found it in the textbook. We were never taught it in class, so I was trying to find another way to do it, but oh well :P
