Most General Form of the Rate-Equation Approximation
The discussion centers on the Rate-Equation Approximation used in quantum optics and laser physics for solving ordinary differential equations (ODEs). The primary equation discussed is ##\dot{\alpha}(t) = (-i\omega-\Gamma) \alpha(t)+F(t)##, with the solution derived using the integrating factor technique. The approximation allows ##F(z)## to be treated as a slowly varying function, enabling simplifications in the integral. The conversation also touches on variations of the approximation when ##F(t)## is coupled with another ODE, specifically ##\dot{F}(t) = -i\Omega F(t) + \beta \alpha(t)##, raising questions about the additional exponential factor in the solution.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with quantum optics principles
  • Knowledge of integrating factor techniques in differential equations
  • Basic concepts of laser physics and rate equations
  • Study the application of the Rate-Equation Approximation in various quantum optics scenarios
  • Explore the derivation and implications of coupled ODEs in laser physics
  • Learn about the role of slowly varying functions in differential equations
  • Investigate the mathematical properties of exponential functions in integrals
Researchers in quantum optics, laser physicists, and students studying differential equations in the context of optical systems will benefit from this discussion.
AdvPhBird
Most General Form of the "Rate-Equation Approximation"
In quantum optics or laser physics, while solving an ordinary differential equation (ODE) using the integrating factor, the so-called Rate-Equation Approximation is used. I have come across different sources implementing it differently. For example, if I have an equation say:
where ##F(t)## is a function slowly varying with respect to time. Solving for ##\alpha(t)## (using the integrating factor technique) we get
##\alpha(t) = \int_0^t dz\,e^{-(i\omega+\Gamma) (t-z)}F(z)##
Assume that the initial conditions die away or are zero. Now, we apply the rate-equation approximation by claiming that ##F(z)## is slow compared to ##e^{-i\omega z}##. Therefore, ##e^{-i\omega z}## "effectively" acts as a sampling function on ##F(z)## and we can pull it out of the integral to get
##\alpha(t) = F(t) \int_{-\infty}^t dz\,e^{-(i\omega+\Gamma) (t-z)}##
The lower limit was taken to be ##-\infty## because most of the physics is occurring at ##t## and it is also computationally convenient since the integrand vanishes in this limit. However, I have also come across implementations of this type of approximation where we also have an ODE in ##F(t)##. Say it has the form
where ##\beta## is some constant. In this case, when you pull ##F(z)## out of the integral you would get something like
##\alpha(t) = F(t) \int_{-\infty}^t dz\,e^{-(i(\omega-\Omega)+\Gamma) (t-z)}##
I don't understand where this extra factor of ##e^{i\Omega) (t-z)}## is coming from. So my question is (as the title suggests) what is the most general form of this rate-equation approximation?
Note: I am aware that this is simply a set of coupled ODEs which can be solved exactly using standard techniques. But I am specifically interested in the application of this approximation.
In the second example, F is not slowly varying, but is the product of a slowly varying function and exp(i Omega t). The second factor is therefore left in the integral.
  • · Replies 0 ·
  • · Replies 24 ·
  • · Replies 0 ·
