Proving m<f(x)<M for f(x)=\frac{x}{x^2 +x+1}
  • Thread starter Thread starter Andrax
The problem involves proving that for the function f(x) = \(\frac{x}{x^2 + x + 1}\), there exist real numbers m and M such that m < f(x) < M for all x in the real numbers. The original poster attempts to establish bounds for f(x) based on observations from a graph.
  • Participants discuss the values of m and M, with some suggesting a direct approach to prove the inequality. Others raise concerns about the lack of explicit mention of these bounds in the problem statement, indicating a need for manual derivation.
The discussion is ongoing, with participants exploring different methods to establish the bounds for f(x). Some guidance has been offered regarding the conditions for real solutions of a related quadratic equation, which may help in determining the necessary bounds.
There is a noted constraint that the problem does not explicitly provide the values of m and M, leading to questions about how to derive these bounds independently.
Andrax
prove that m<f(x)<M
so [itex]\forallx[/itex][itex]\in[/itex]R: f(x)=[itex]\frac{x}{x^2 +x+1}[/itex]
the question is prove that m[itex]\leq[/itex]f(x)[itex]\leq[/itex]M
M and m are real numbers
all i did so far was making f(x) : (x+1)^2 +(3/4) well i noticed that m=-1 and M=4/3 from the graph but i can't really prove it well
f(x)= 1-[itex]\frac{x^2+1}{x^2 +x +1}[/itex] = 1-[itex]\frac{x^2+1}{(x+1/2)^2+3/4}[/itex]
If you know the values of m = -1 and M = 4/3, you can try a direct approach:
If you want to prove ##-1 \leq \frac x{x^2+x+1}##, you can multiply both sides of that inequality by ##(x^2+x+1) = (x+\frac12)^2+\frac34##, which is positive (and so will not change the direction of the ##\leq## relation symbol):
-(x^2+x+1) \leq \frac{x(x^2+x+1)}{x^2+x+1}.
Can you now prove that this inequality is true?
well there is a slight problem here the exercise doesn't mention the -1 nor the 4/3
so they are expecting us to do it "manually".
One approach to this sort of problem is to ask "What conditions must [itex]y[/itex] satisfy for [itex]y = f(x)[/itex] to have real solutions for [itex]x[/itex]?"
This is a particularly good approach in this case, because if [itex]y = x/(x^2 + x + 1)[/itex] then
[tex]yx^2 + (y-1)x + y = 0[/tex]
and hopefully you know the condition for that quadratic in [itex]x[/itex] to have real roots. That will give you a condition which [itex]y[/itex] must satisfy, which in turn will give you bounds for [itex]f(x)[/itex].
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 19 ·
