Production of large volumes of duterated hydrocarbons?
  • Thread starter Thread starter Hologram0110
    Volumes
The discussion revolves around the feasibility and cost of producing deuterated hydrocarbons on a large scale, particularly for use as organic coolants in nuclear reactors. Participants explore various methods of synthesis, the implications of using deuterium instead of hydrogen, and the economic considerations involved.
  • One participant questions the difficulty and expense of producing 100 tonnes of hydrocarbons with 95% deuterium, referencing Monsanto OS-84 as a potential example.
  • Another participant asserts that the cost of producing deuterated hydrocarbons would be higher due to the initial expense of deuterium (D2).
  • A participant mentions the retail price of D2O, indicating that deuterated hydrocarbons are significantly more expensive.
  • Concerns are raised about the capital cost of deuterium in nuclear plants and the challenges of synthesizing hydrocarbons without introducing hydrogen, particularly from D2O.
  • Discussion includes the possibility of using D2O with carbon to create deuterated hydrocarbons, questioning the feasibility of such processes at larger scales.
  • Another participant notes that synthesis of deuterated compounds often involves D2 gas and highlights potential issues with using deuterium oxide as a solvent in organic reactions.
  • One participant suggests specific reactions, such as producing methane and formic acid from D2O, indicating pathways to obtain various hydrocarbons.
Participants express differing views on the feasibility and cost implications of producing deuterated hydrocarbons, with no consensus reached on the best methods or economic viability.
Participants note limitations related to the availability of deuterium, the challenges of reaction conditions, and the potential need for specific solvents in organic chemistry, which remain unresolved.
Hologram0110
Hi everyone,
I'm a nuclear engineering student so my chemistry knowledge is limited to a couple of courses in first year so please be patient with me.
I was wondering how difficult or expensive would it be to produce hydrocarbons with deuterium instead of hydrogen on a large scale? (say 100 tonnes with 95% or better Deuterium?) What about something like Monsanto OS-84 which is a mixture of partially hydrogenated terphenyls? (This has been used in the past as a coolant for nuclear reactors)
I ask because organic coolant for nuclear reactors offers some potential safety improvements but the hydrogen can absorb a significant number of neutrons compared to deuterium. I was wondering if the cost of producing duterated hydrocarbons would be more or less than the cost of the deterium to begin with.
All of the googling I've done went way over my head. I also think it was for laboratory scale production.
Chemistry news on Phys.org
Hologram0110 said:
Hi everyone,
It would be more since you start with deuterium (D2) when you make deutero-substituted organics.
1 kg of D2O from United Nuclear retails for US $695.00, so the cost of deuterated HCs is quite a bit more expensive.
The cost of deuterium is a major part of the capital cost of some nuclear plants (research reactors, CANDU's, plutonium breeders).
Say you have deuterium in the for of D2O. How hard is it to make hydrocarbons without mixing deterium with hydrogen (which would down blend your D2O supply).
Could you start a process where you take nearly pure D2O add some carbon in some chemical form (with very little H) under the right temperature, pressure and catalyst to efficiently turn the D2O into deterocarbons? Can you eventually convert them to more complex longer/chain molecules (terphenyls, benzene)
My recollection from my high school organic chemistry class is yes, but all the reagents already had hydrogen in them. How would you go about it if you wanted to not introduce hydrogen to the mix? Is there a process that is conceivable at larger scales?
As chemistree noted, synthesis of deuterated compounds typically involves D2(g). I know there's quite a bit of older literature on the use of transition metals, deuterium oxide, and DCl to produce deuterated compounds, but my (vague) recollection is that certain compounds and/or functional groups are more likely to end up deuterated than others.
A general concern is that if you need to use deuterium oxide for this scheme of yours, you will have trouble getting some reactions to work as they'd prefer a different type of solvent. Not everything wants to behave well in aqueous solvent, especially in organic chemistry.
You could make methane from Al2C3 and D2O.
Ethin from CaC2 and D2O. Formic acid from CO and D2O.
I suppose many other hydrocarbons can then be obtained from these compounds e.g. electrochemically.
  • · Replies 21 ·
32K
