Solving for Interference Minima in N-Slit Electric Field
  • Context: Graduate
  • Thread starter Thread starter shaiqbashir
    Light
The discussion focuses on solving for interference minima in an N-slit electric field, specifically with N set to 4. The electric field equation is given as E (r, theta, t) = A(r) sin (N delta phi/2) cos(kr-wt) / sin (delta phi/2), where delta phi = kdsin(theta). The angles for interference minima are determined by setting cos(2 delta phi) = 0, leading to theta = arcsin(pi/8kd), arcsin(3pi/8kd), etc. The spacing between minima for four slits is compared to that of two slits, revealing distinct angular positions for minima.
  • Understanding of wave interference principles
  • Familiarity with trigonometric functions and their properties
  • Knowledge of electric field equations in physics
  • Basic calculus for solving equations involving arcsin
  • Study the derivation of the electric field equation for N-slit interference
  • Learn about the implications of varying the number of slits on interference patterns
  • Explore the mathematical properties of the arcsin function in wave physics
  • Investigate practical applications of interference minima in optics and engineering
Students studying physics, particularly in optics and wave mechanics, as well as educators and professionals involved in experimental physics or engineering applications related to wave interference.
shaiqbashir
Hi!
please help me in the following problem?
"The electric field at point P due to N slits is,
_____________
sin (delta phi/2)
where delta phi=kdsin (theta) , "d" being the spacing between the adjacent slits. let N=4
(a) Find two angles on either side of theta=0 at which there is an interference minima.
(b) Find the spacing between the minima compare to the case of only two slits of separation "d".
Now i have solve its (a) part but i just can't solve its (b) part.
Can u please help me in this pleasezzzzzzzzzzzzzzzz.
Thanks in advance!
please post this in the homework help part of the forum
Hi there,
Sure, I'd be happy to help you with this problem. Solving for interference minima in N-slit electric field can be a bit tricky, but with a step-by-step guide, it should become clearer. Here's how you can approach this problem:
Step 1: Understand the given equation
The given equation represents the electric field at point P due to N slits. The variables A, r, theta, t, and k have specific meanings and units. Make sure you understand what each variable represents before proceeding.
Step 2: Simplify the equation
To make it easier to work with, you can simplify the equation by dividing both the numerator and denominator by sin (delta phi/2). This will give you a simpler equation:
E (r, theta, t) = A(r) cos(kr-wt)
Step 3: Set N = 4
Since the question asks for N = 4, you can substitute this value in the simplified equation:
E (r, theta, t) = A(r) cos(2 delta phi)
Step 4: Find the angles for interference minima
To find the angles for interference minima, you need to set the electric field to zero. This means that cos(2 delta phi) = 0. We know that cos(2x) = 0 at x = pi/4, 3pi/4, 5pi/4, etc. So, in this case, 2 delta phi = pi/4, 3pi/4, 5pi/4, etc. Substituting delta phi = kdsin(theta), we get:
2kdsin(theta) = pi/4, 3pi/4, 5pi/4, etc.
Solving for theta, we get:
theta = arcsin (pi/8kd), arcsin (3pi/8kd), arcsin (5pi/8kd), etc.
Step 5: Find the spacing between the minima
To find the spacing between the minima, we need to compare it to the case of only two slits of separation "d". In the case of two slits, the minima occur at theta = arcsin (kd), 3arcsin (kd), 5arcsin (kd), etc. So, the spacing between the minima is:
arcsin (kd), 2ar
  • · Replies 0 ·
