Solve Ampere's Law & Displacement Current: Capacitor Voltage Change
  • Thread starter Thread starter airkapp
    Maxwell
The discussion focuses on calculating the rate of change of the electric field (dE/dt) between the plates of a capacitor with a diameter of 6.0 cm and a separation of 1.3 mm, under a changing voltage of 120V/s. The area (A) of the capacitor plates is determined to be 0.006 m². The displacement current (I_d) is derived using Ampere's Law, leading to the formula dE/dt = (μ_0I)/A. Substituting the values results in a calculated dE/dt of 2.0 x 10^-4 T/s, indicating the rate at which the electric field changes.
  • Understanding of Ampere's Law
  • Knowledge of displacement current
  • Familiarity with the concepts of electric field and voltage
  • Basic proficiency in calculus for rate of change calculations
  • Study the derivation of displacement current in detail
  • Learn about the applications of Ampere's Law in electromagnetic theory
  • Explore the relationship between electric fields and capacitance
  • Investigate the role of permittivity and permeability in electromagnetic equations
Students of physics, electrical engineers, and anyone interested in understanding electromagnetic theory and the behavior of capacitors in changing electric fields.
airkapp
Ampere's Law and Displacement Current...anybody?
Determine the rate at which the electric field changes between the round plates of a capacitor, 6.0 cm in diameter, if the plates are spaced 1.3 mm apart and the voltage across them is changing at a rate of 120V/s
I found area:
A = 2πr2 = 2 π(.03 m)2
= .006 m
then do I solve for dE/dt ?
Why do you need area to find E?
Yes, you can solve for the rate of change of electric field (dE/dt) using the equation for displacement current, which is given by:
dE/dt = (I_d)/(Aε_0)
Where I_d is the displacement current, A is the area between the plates, and ε_0 is the permittivity of free space.
In this case, the displacement current can be calculated using Ampere's Law, which states that the line integral of the magnetic field around a closed loop is equal to the current passing through the loop. Since there is no current passing through the loop, the displacement current is equal to the rate of change of electric field.
Therefore, we can rewrite the equation as:
dE/dt = (μ_0I)/A
Where μ_0 is the permeability of free space.
Now, we can plug in the given values:
dE/dt = (μ_0(120V/s))/(.006 m)
= 2.0 x 10^-4 T/s
This is the rate at which the electric field is changing between the plates of the capacitor.
  • · Replies 29 ·
