Register to reply
Calculating Beam Deflection using Double Integration
by mm391
Tags: beam, deflection, double, integration
Share this thread:
mm391
#1
Dec26-12, 08:30 AM
P: 63
If the distributed force is removed from the beam in the picture attached and not considered, calculate the deflection at point D.
2. Relevant equations
Double integration for deflection [V]
3. The attempt at a solution
Moment = Ra*x-P(x-3*L) =
Slope = 1/EI*((7p/4)*(x^2/2)-(Px^2/2)-(3PL)+c1)
Deflection = 1/EI*((7p/4)*(x^3/6)-(Px^3/6)-(3PL)+(c1*x)+c2)
Boundary Conditions to calculate c1 and c2
x=0=4L V=0
I am not sure of another boundary condition. I thought maybe
x=2L Slope=0 but I do not think this is right.
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
SteamKing
#2
Dec26-12, 09:59 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,314
Your boundary conditions at A and B are very curious.
Since the beam is simply supported at both A and B, what BC must apply?
(Hint: they will both be the same)
mm391
#3
Dec26-12, 10:06 AM
P: 63
When x=0 V=0
or
When x=4L V=0
This is because they are simply supported so therefore there can be no deflection at either end. But don't I need a BC for the slope. As there is an unknown slope at A and B how can I find one to use?
SteamKing
#4
Dec26-12, 12:09 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,314
I'm confused. V usually represents the shear force. Are you using it to denote deflection?
SteamKing
#5
Dec26-12, 03:54 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,314
I reread your OP.
You can still use the BCs for deflection at A and B since you have only two unknown constants of integration.
mm391
#6
Dec27-12, 06:33 AM
P: 63
Sorry out lecturer started using V for deflection but I see in most text books it is U.
How can i calculate C1 if I don't have a boundary condition for a slope?
SteamKing
#7
Dec27-12, 11:34 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,314
You can't specify a slope for a simply supported beam.
Your two BCs are the deflections at A and B, both of which are zero.
mm391
#8
Jan2-13, 11:42 AM
P: 63
From my boundary conditions I have:
c1=-PL^2/8
c2= 3PL
Using these I still have the wrong answer for the defelction at D. Can anyone see where I maybe going wrong?
SteamKing
#9
Jan2-13, 01:27 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,314
What reactions did you calculate at A and B?
mm391
#10
Jan4-13, 06:28 AM
P: 63
I made a mistake. I worked out the reactions which included the Distributed load. The question asks us to ignore the distributed load.
In which case my reactions are:
Reactions@A= P/4
Reactions @B=3P/4
The of the beam from the left hand side of P is (P/4)*x = M1
The moment from 3L<x<4L is (p/4)*(x)-P(x-3L) = M2
Boundary conditions I can see are (now using U as the deflction):
x=0 U=0
x=3L Slope=0 (although I am not sure this is correct as we are given no info about the slope)
x=4L U=0
Is this correct?
Sorry I am struggling to see where I am going wrong.
SteamKing
#11
Jan4-13, 10:57 AM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,314
Two boundary conditions are sufficient, since there are only two constants of integration. The BCs at the ends are easily determined by inspection. Although there is a point of zero slope somewhere between A and B, it may not necessarily be at x = 3l.
Register to reply
Related Discussions
Beam bending problem, calculate deflection of a beam Engineering, Comp Sci, & Technology Homework 7
Beam deflection in a cantilever beam Mechanical Engineering 3
Deflection on I Beam Mechanical Engineering 8
Deflection of a Beam using Double Integration Engineering, Comp Sci, & Technology Homework 4
Beam deflection General Engineering 4
