New Reply
Condition of continuity of E field at a boundary
Share Thread Thread Tools
Dec28-12, 08:40 PM   #1
I am trying to understand the derivation of Snell's law using Maxwell's equation and got stuck.
My text book says that "the E field that is tangent to the interface must be continuous" in order to consider refraction of light.
If it were static E field I understand this is true because in electrostatics
rotE = 0
holds. However Snell's law describes how electromagnetic waves change their direction of propagation when going through an interface of two mediums. Since our E filed is changing dynamically, we should use the equation
rotE = -∂B/∂t
in stead. To me it is not obvious why this equation leads to the continuity condition.
How does the continuity condition in Snell's law appears from Maxwell's equations?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Dec28-12, 10:07 PM   #2
Recognitions:
Homework Helper Homework Help
B also has boundary conditions.
www.cem.msu.edu/~cem835/Lecture03.pdf
Dec29-12, 07:15 AM   #3
Recognitions:
The continuity of E tangential comes from applying Stokes' theorem to rotE = -∂B/∂t.
The area for [tex]\int{\bf dS}\partial_t{\bf B}[/tex] shrinks to zero.
Dec29-12, 11:25 AM   #4
Quote by Meir Achuz View Post
Stokes's theorem for rotE is
[tex]\int{ rot\bf{E}}{\bf dS}= \oint _{∂S} \bf Edx = \oint _{∂S} \bf \partial_t B dx [/tex]
How does this lead to the continuity condition?
Dec29-12, 03:34 PM   #5
Mentor
http://farside.ph.utexas.edu/teachin...es/node59.html
Note the left-hand portion of the diagram at the top of the page, and start reading around equation (635).
Dec30-12, 05:11 PM   #6
OK I see. It seems like the continuity condition is something to do with the fact that the interface has zero volume and the planar surface is sufficiently large.
The path of line integration must be an infinitely thin rectangular when the area of the box approaches to 0.
The shape of the box is the key because it will allow the line integration to become 0 even if rotE is non-zero.
Thanks for all the replies.
Will the same rule apply if there is a gradient layer between the two phases?
Let's say the geometry is no longer flat but curved, and the curvature of radius is comparable to the thickness of gradient layer.
I'm pretty sure that the parallel component of the E field strength will still be continuous at any point.
But will the phase still be the same?
Jan1-13, 08:33 PM   #7
Recognitions:
Quote by Gen1111 View Post
You know what the answer has to be already - what usually happens to Snell's Law when the surface is curved or the interface is not sharp?
You could try working it out for a simple setup - like a spherical interface (par-axial) - and see if the general boundary conditions give you the appropriate equations.
New Reply
Thread Tools
Similar Threads for: Condition of continuity of E field at a boundary
Thread Forum Replies
What does this boundary condition mean? Classical Physics 4
Condition for local absolute continuity to imply uniform continuity Calculus 0
Boundary Condition Calculus & Beyond Homework 7
boundary condition of EM field Classical Physics 3
Waveguide H field boundary condition Electrical Engineering 0
