Why is the derivative of e^(2x) equal to 2e^(2x)?
  • Context: Undergrad
  • Thread starter Thread starter gokuls
    Derivative
The discussion centers around the derivative of the function e^(2x) and the application of the chain rule in calculus. Participants explore the reasoning behind why the derivative is expressed as 2e^(2x) rather than simply applying the derivative of e^x in a straightforward manner. The conversation includes intuitive explanations, mathematical reasoning, and the exploration of derivative rules.
  • Some participants express confusion about the chain rule and its application to the function e^(2x), questioning why the derivative involves a factor of 2.
  • One participant suggests that understanding the intuition behind the chain rule is more beneficial than merely defining it.
  • A participant presents a breakdown of the function using composition, defining h(x) = e^(2x) as (g ∘ f)(x) = (f(x))^2, and discusses the need for all instances of "x" to be inside the parentheses for proper decomposition.
  • Another participant introduces the concept of magnification in relation to the chain rule, likening the process to passing through two lenses, where the total magnification is the product of the individual magnifications.
  • One participant notes that the derivative of a squared function does not equal the square of the derivative, referencing the product rule to clarify this point.
  • A later reply discusses the behavior of the function e^x and how changes in x affect the function's value, emphasizing the role of the exponent in determining the rate of change.
Participants do not reach a consensus on the best way to intuitively understand the chain rule and its application to the derivative of e^(2x). Various viewpoints and explanations are presented, indicating that multiple competing interpretations exist.
Some participants highlight the limitations of understanding the chain rule purely through definitions, suggesting that intuition and visualizations may be necessary for deeper comprehension. There are also references to the need for clarity in mathematical expressions and the conditions under which derivative rules apply.
gokuls
Maybe I'm not fully understanding the chain rule, but anyways I'll give my argument. At any given point the function e^(2x) is squared the original function of e^x. So why is the derivative of e^(2x), two times the squared the derivative of the e^x, and not just squared the derivative of the latter function? Hope you understand what I'm saying. If you don't understand, let me know I'll elucidate. Also when you try to explain, please do not just regurgitate the definition of chain rule, but try to explain the intuition behind this.
Ok instead of defining the chain rule, why not try to learn about the chain rule in an intuitive sense.
Okay, could you please explain the intuition?
Let:
h(x) = e^(2x)
f(x) = e^x
g(x) = x^2
Our the function we're interested in
(g ∘ f)(x) = g(f(x)) = (f(x))^2 = ((e^x)^2) = e^(2x) = h(x)
You know how to use the chain rule here. What you're asking is why can't we write it:
h(x) = e^(2x) = e^(x2) = (e^2)^x = ...
and go on from there to use the chain rule on different functions. (Let me know if this isn't what you meant).
The problem is doing that, you can't end up with the composition of two interesting functions. In order to decompose functions, you need all instances of "x" inside the parentheses. (This isn't a hard, fast law, but you need to be able to factor out a all instances of x).
The chain rule is the only thing that's going to help you with this one, I think.
Also, I'm not sure "intuition" is what you should be looking for here.
What is the intuition that x^(yz) = (x^y)^z?
If you can do that one, perhaps it isn't so hard to understand why (g ∘ f)' = (g' ∘ f) f'
An amusing way to think about the chain rule is to think about it as a statement about the magnification power of a system of two lenses. ( I read this in a calculus book, but I don't recall the book's title.)
The quotient in the definition of derivative resembles a magnifcation ratio. The size of the original image is (x+h) - h = h. The size of the magnified (or contracted) image is f(x + h) - f(x) The ratio of magnification for the "lens" f is (f(x+h)-f(x))/h. For small h, this is approximately the derivative f'(x).
The composition of two function f(g(x)) is thought about as the application of two lenses to the image. We send the original image through the lens g. Then we send that image though the lens f. Thinking about it this way, it is intuitive that the total magnification of the process is the product of the magnification of f times the magnifcation of g.
Think of e^(2x) as f(g(x)) with g(x) = 2x and f(t) = e^t, where t = g(x). The magnifcation of g is g'(x) = 2. The magnifcation of f is f'(t) = e^t where t = g(x). Think of x passing through both lenses. It goes into g first and then into f. The lens g magnifes by 2. The lens f magnifies by e^t = e^(g(x) = e^(2x). The total magnification is the product (2)(e^(2x)).
You can look at it that way by using f(t) = t^2 and g(x) = e^x. The magnification of f is f'(t) = 2t. The magnifcation of g is g'(x) = e^x. The product is (2t)(e^x) = (2 g(x) ) e^x = (2 e^x) (e^x) = 2 e^(2x).
Chain rule, as everyone pointed out, but I didn't notice anyone noting why
[tex]\left(\left(e^x\right)^2\right)'\ne\left(\left(e^x\right)'\right)^2[/tex]
The reason is simply that
[tex]\left(f^2\left(x\right)\right)' \ne\left(f'\left(x\right)\right)^2[/tex]
Use the product rule if you want to see why this is.
If you consider a small section of the function e^x, it will resemble a straight line. Now the derivative says how much does the functions value increase per small increases in x. So let's say your function's value increases 0.04 units if you increase x by 0.01 when x is around some value A. Since the function is rather straight if you go in small steps, if you would increase x by 0.02 units, the function would increase by 0.08, if you increased x by 0.03, the function would increase by 0.12, roughly speaking, because it is not perfectly a straight line.
Now instead of e^x consider e^(2x). When 2x is around A, the functions have the same value, but if you now increase x by 0.01, the whole exponent increases by 0.02, which as we saw before, increasing the exponent by 0.02 increases the function by 0.08, so we get twice as much change in the function's value per an increase in x of 0.01 as we did before, because the exponent increases twice as much as before per the same change in x.
The exponent doesn't have to be linear like that, you just need to know how much does the whole exponent increase with changes of x and that is what the derivative of the exponent shows.
  • · Replies 53 ·
