How big bodies can exist in outer Solar System?
The discussion centers on the potential existence of large celestial bodies in the outer Solar System, particularly beyond the known planets and dwarf planets. Participants explore observational limitations, theoretical constraints, and the implications of mass distribution in the Kuiper Belt and Oort Cloud.
  • Some participants propose that large, unseen objects could exist at significant distances, with estimates suggesting Earth-sized objects could be missed at around 200 a.u. and Jupiter-sized objects at 800 a.u.
  • There is a claim that technological limitations of current telescopes restrict our ability to detect these distant objects.
  • One participant questions the validity of naming hypothetical objects that are not theorized to exist, expressing skepticism about the existence of large bodies beyond known celestial bodies.
  • Constraints on mass in the Kuiper Belt and Oort Cloud are discussed, with some suggesting it cannot exceed a few Earth masses without affecting planetary orbits.
  • There are conflicting views on whether larger bodies could exist in the Oort Cloud, with some suggesting it could contain objects as large as Jupiter.
  • Participants discuss the observational history of Eris and the implications for detecting other large bodies, noting that Eris was only recently discovered despite its size.
  • Some participants highlight the theoretical limits of gaseous planets, suggesting that objects can exist up to 15 Jupiter masses before becoming brown dwarfs.
  • There is a debate about the visibility of objects at great distances, with some arguing that distance alone does not preclude detection if the right observational techniques are employed.
Participants express multiple competing views regarding the existence and size of unseen bodies in the outer Solar System. There is no consensus on the limits of mass or the implications for planetary orbits, and the discussion remains unresolved.
Limitations in observational technology and the definitions of celestial bodies are noted, as well as the dependence on the mass distribution in the Kuiper Belt and Oort Cloud. The discussion also highlights the uncertainty surrounding the detection of large bodies at significant distances.
snorkack
Well, how big things can exist unseen?
We did see Pluto - but very importantly managed to not see Eris till very recently. What else may we not see?
Eris at 95 a. u. was found recently. The total luminosity of a reflective object decreases with fourth power of distance, so that we could miss an Earth-sized object at about 200 a. u., Neptune sized object at 450 a. u. and Jupiter sized object at 800 a. u.
There is stuff out there at 900 a. u., because that is where Sedna´s aphelion is. Can we observationally rule out a brown dwarf star at Sedna´s orbit? Nothing is bigger than Jupiter except red dwarf and bigger stars, something which we do have observational evidence against (a star the size of Proxima Centauri and as far from Sun as Proxima is from Toliman would be a naked eye object, though an inconspicuous one).
We know that Neptune has some inner heat. But then, we know where to look. Would a body as big and hot as Neptune (50 000 km and 50 K) located far enough to be missed in reflected visible light (say 500 a. u.) be seen in infrared?
Astronomy news on Phys.org
There is no fundamental size limit. The limits we have are technological - how powerful are present day telescopes.
How can something that isn't even theorized to exist already have a name? :rolleyes:
There are constraints on how much mass can exist in the kuiper belt/oort cloud without noticeably affecting planetary orbits. It is not more than a few Earth masses.
Found a claim that WISE would have seen Neptune at 700 AU and Jupiter at 63 000 AU.
*Disclaimer - not a physicist but thought I'd try and chip in.*
snorkack said:
Well, how big things can exist unseen? We did see Pluto - but very importantly managed to not see Eris till very recently. What else may we not see?
Firstly, when you say big, don't underestimate how 'big' space is. The needle in a haystack analogy does no justice to the relative size of dwarf planets and the solar system.
Where did you hear/read that Jupiter was the biggest thing appart from red dwafs and bigger stars? Theoretically, in terms of gaseous planets, they can exist to be up to 15 Jupiter masses or so before there is enough pressure in the core to ignite deuterium fusion, hence becoming “brown dwarfs” rather than planets. The biggest planet in the Universe (at the time of this writing)* is TrES-4, which is located 1,400 light years away in the constellation Hercules. The planet has been measured to be 1.4 times the size of Jupiter, although it is only 0.84 times Jupiter’s mass.
* http://www.universetoday.com/13757/how-big-do-planets-get/#ixzz2ILYfkycT
... or did you mean it's the biggest thing you can see with the naked eye that isn't a star?
What makes you think that something 500AU away would not be visible? where did you get that information?
Is your question referring to the size of an object and the limits of the lenses we use, i.e. resolution of an object due to the focal length etc. of the lens you are using not allowing you to see objects beyond a certain distance?
As for the distance of our observations, "According to calculations, the comoving distance (current proper distance) to particles from the CMBR, which represent the radius of the visible universe, is about 14.0 billion parsecs (about 45.7 billion light years), while the comoving distance to the edge of the observable universe is about 14.3 billion parsecs (about 46.6 billion light years)"**
UDFj-39546284 is the designation given to a stellar structure reported January 27, 2011, as light from the oldest object detected through infrared, this is 13.75 light years away***
** http://en.wikipedia.org/wiki/Observable_universe
*** http://en.wikipedia.org/wiki/UDFj-39546284
1 light year is roughly 63,241.077 AU so we can at least observe things well in excess of 500 AU away. But as I mentioned the way in which you observe them i.e. the lenses you use etc will effect the resolution of what you can observe...
Again I should note that I'm not a physicist so my apologies if none of this is useful in answering your question. And apologies to any physicists if I've made any blinding errors!
Yes, but it is a hot Jupiter bloated by nearby star - and its size was a theoretical surprise even so.
Jupiter is 3 times the mass of Saturn, but mere 15% bigger, because of compressibility. It is generally expected that objests more massive than Jupiter but less massive than red dwarfs are compressed by gravity so that they are not bigger than Jupiter.
Read the second and third paragraphs in my original post.
Eris, 2300 km across and 97 AU away, was spotted only recently - missed until then.
A planet 5 times further away than Eris but 25 times larger in radius would have 625 times the area of Eris. This area would receive and reflect back 25 times the sunlight Eris does, but the amount of reflected light reaching Earth would equal the amount received from Eris. Since we missed Eris till recently, we could have missed a planet bigger than Neptune and inside 500 AU in the same way.
The Kuiper belt does not have enough mass for really big (solid) objects -> see here for some numbers.
The Oort cloud, on the other hand, could contain bigger objects, even as big as Jupiter.
Weissman estimated the Oort cloud contains around 2 Earth masses - http://articles.adsabs.harvard.edu/cgi-bin/nph-iarticle_query?1983A%26A...118...90W&data_type=PDF_HIGH&whole_paper=YES&type=PRINTER&filetype=.pdf
That is just the mass of comets ("The total mass of comets in the Oort cloud is calculated"). Anything orbiting in a circular orbit (or at least with a perihelion in the Oort cloud) is not included, I think.
orbits would be affected. the bigger the body the bigger the effect.
the effects could lead orbital migration, differing orbital resonences
etc..
so what can dictate the size of a body in the outer solar system?
well if it was made within the solar system, the amount of gas and or rock the body can gravitationally attract before it either runs out of material ( due to the materials scarsity and/or the protosun undergoing steller wind/bi polar outflow blowing the material away). and then plantery migration can cause this bosy to migrate to the outer system.
another scenario is that a massive body formed else where somehow got captured (unlikely).
and calculations have shown that the orbits of the current system tally with the mass detected.
Eris is the 4th brightest TNO (trans-neptunian object), but it was about the 500th one discovered. Brightness isn't everything. Eris went undetected because of how slow it moves against the background stars. The discovery of Sedna, also slow-moving, made Mike Brown lower his velocity threshold in the searches to discover more slow-moving objects. But the lower the threshold, the more false-positives.
  • · Replies 0 ·
  • · Replies 21 ·
