| New Reply |
Coefficient of Drag |
Share Thread | Thread Tools |
| Jan12-13, 04:29 AM | #1 |
Coefficient of Drag
Hello,
I understood that in low velocities the standrad drag equation: [tex]F_d=\frac{ρv^2C_dA}{2}[/tex] Could linearized to something like: [tex]F_d=γv[/tex] I am looking for the drag coefficient(either γ or Cd) for either a prolate or a tri-axial ellipsoid at low velocities (less than 0.5 m/s) in water. I found some papers providing drag coefficients for relatively high velocities but none with drag coefficients for low velocities. Best regards |
| Jan12-13, 12:26 PM | #2 |
For spheres, the drag coefficient at low velocities can be determined analytically, see e.g. the book of Clift, Grace and Weber - Bubbles, Drops and Particles or Happel and Brenner, Low Reynolds number hydrodynamics. It is
[itex]\mathrm{C_d}=\frac{24}{\mathrm{Re}}[/itex] With the Reynolds number [itex]\mathrm{Re}=\frac{\rho v D}{\mu}[/itex] Because A is the cross-sectional surface of the sphere, the force can be written as: [itex]F_d=3\pi \mu D v[/itex], which is known as Stokes' law. The drag of a nonspherical particle depends on its orientation with respect to the mean flow. For a prolate with aspect ratio E=b/a and oriented such that that the short axis with length a (from center to edge) is in the direction of the flow, the drag component is approximately [itex]F_d=1.2\pi \mu (4+E) a v[/itex]. Note that when E=1, then 2a=D and Stokes' result is recovered. The derivation is for instance in Happel and Brenner's book. |
| New Reply |
| Thread Tools | |
Similar Threads for: Coefficient of Drag
| Wind drag, drag coefficient | Introductory Physics Homework | 0 | ||
| Drag Force / Drag Coefficient | Introductory Physics Homework | 5 | ||
| Drag coefficient | Introductory Physics Homework | 1 | ||
| drag coefficient | General Physics | 1 | ||
| Fluid Mechanics - Drag coefficient and Pressure coefficient | Mechanical Engineering | 1 | ||
