Cooling Pipe: Need Options for 45° Temp Drop
The discussion focuses on cooling a pipe to achieve a temperature 5 degrees below the external temperature, specifically targeting a scenario where the outside temperature is 45 degrees Fahrenheit, resulting in a desired internal temperature of 40 degrees. The user, Raviteja Lingineni, seeks solutions that involve external cooling methods, such as using a block of ice, while emphasizing that no modifications to the pipe itself or the introduction of substances other than air are permitted. Participants in the forum are encouraged to provide innovative cooling techniques that adhere to these constraints.
  • Understanding of thermal conductivity and heat transfer principles
  • Familiarity with passive cooling techniques
  • Knowledge of materials with high thermal mass
  • Basic concepts of fluid dynamics related to air flow
  • Research passive cooling methods using ice or other thermal mass materials
  • Explore the use of insulation materials to minimize heat transfer
  • Investigate the design of air flow systems to enhance cooling efficiency
  • Learn about the principles of evaporative cooling and its applications
Mechanical engineers, HVAC professionals, and anyone involved in thermal management or cooling system design will benefit from this discussion.
rlingineni
I have a pipe that needs to be 5 degrees below the external temperature outside(eg- 45 degrees outside means 40 degrees within). I cannot remove the pipe or anything, all I can change is the what the pipe passes through, for example if it passes a block of ice then technically the pipe would cool also. So basically do you guys have any suggestions for what I can use to cool the pipe(also no sending anything through it besides air.
I would appreciate any suggestions.
Thank You,
Raviteja Lingineni
Moderator's note: thread moved from General Physics to Mechanical Engineering.
