Questions about graduate studies?
  • Thread starter Thread starter M. next
    Graduate Studies
The discussion revolves around the criteria American universities consider during graduate admissions, specifically focusing on GPA types (cumulative vs. major GPA) and the timing of application reviews. Participants also inquire about the implications of submitting applications early and the rationale behind multiple application deadlines.
  • Homework-related
  • Meta-discussion
  • Some participants suggest that many departments consider both cumulative and major GPAs, with a strong major GPA potentially compensating for a lower overall GPA, but this varies by institution.
  • It is noted that a minimum overall GPA of 3.0 is often required, but competitive programs may expect a higher GPA, typically around 3.4-3.5.
  • There is uncertainty about when applications are read; some participants indicate that while early submissions may be reviewed, final decisions are generally made after the application deadline to allow for comprehensive evaluation.
  • Questions arise regarding the advantages of applying early, with some participants seeking clarity on whether it impacts the admissions process.
  • Participants express curiosity about the purpose of having both regular and late application deadlines, questioning the benefits of multiple deadlines for the same semester.
Participants generally agree that GPA is a significant factor in admissions, but there is no consensus on the specifics of how early applications are handled or the rationale behind multiple deadlines.
Participants acknowledge that variations exist based on different departments and universities, and that additional factors such as GRE scores, research experience, and recommendations may also influence admissions decisions.
Prospective graduate students interested in understanding the admissions process and criteria at American universities may find this discussion relevant.
M. next
What are American Universities interested about? Is it the cumulative average or is it the major average?
Add to that, if you submit you graduate application early, does it start to be read? Or not?
Thanks!
Many departments will ask for both. Most departments will take into account a good major GPA if your overall GPA is somewhat low. Within reason, that is. A 3.8 Major GPA might help make up for having an overall GPA of 3.4 or so. However, if your overall GPA is below 3.0, a high major GPA might not help, since at many universities a 3.0 GPA is the minimum GPA requirement set by the graduate school.
Thanks!
Depends on the department and admissions committee. Many members on this forum have experience being on admissions committees. I do not. Hopefully someone who does will chime in soon.
Thanks a lot. That was helpful. Let's hope they answer.. I am eager to know. :)
I should also add that while 3.0 overall GPA might be the "minimum' at most programs, usually the minimum competitive GPA at most graduate programs is around 3.4-3.5.
As mentioned above, there will be variation in this ballpark competitive GPA depending on your major GPA and other aspects like your GRE, research , recommendations, prestige of graduate school, etc.
Thank you loads, you cleared things up. I just still need to know about the committee and when do they start reading the application. Is it directly? Or when the deadline is crossed..
Thanks!
Some people may read it early but the overall decision will be made after the application deadline so that all applications can be seen together.
I see, thank you. Is there any advantage in applying way early? Or it does not make a difference
Oh yes and concerning regular and late deadlines, what's the difference. I mean why don't they just put one date ( the last one )?
What do they benefit from plugging in two dates for the same semester?
