What is the RMS Voltage Across a Body Near a Transformer?
The discussion focuses on calculating the RMS voltage across a person's body near a transformer with a primary voltage of 120 V at 60 Hz and a secondary voltage of 6000 V. The stray capacitance between the hand and the secondary winding is 10.0 pF, and the body resistance is assumed to be 1 Mega ohm. The maximum voltage across the body is determined using the formula V = IZ, where Z is the impedance of the circuit, and the RMS voltage is calculated as Vrms = Vmax/sqrt(2), resulting in approximately 23 volts across the body.
  • Understanding of AC circuit analysis
  • Familiarity with Ohm's Law
  • Knowledge of impedance in AC circuits
  • Basic concepts of capacitive reactance
  • Learn about calculating impedance in AC circuits using Z = 1/(jωC + 1/R)
  • Study the relationship between maximum voltage and RMS voltage in AC systems
  • Explore the effects of stray capacitance in electrical safety
  • Investigate the physiological effects of electrical current on the human body
Electrical engineers, safety professionals, and anyone involved in high-voltage systems or electrical safety assessments will benefit from this discussion.
andrew410
A person is working near the secondary of a transformer, as shown in the figure below. The primary voltage is 120 V at 60.0 Hz. The capacitance C, which is the stray capacitance between the hand and the secondary winding, is 10.0 pF. Assuming that the person has a body resistance to ground R, determine the rms voltage across the body. (Suggestion: Redraw the circuit with the secondary of the transformer as a simple AC source.)
FIGURE: http://east.ilrn.com/graphing/bca/user/appletImage?dbid=445132339
I need some help with this stuff. This is what I know already. I know that the secondary voltage is 6000 V according to the figure. Also, I know that the rms voltage = max voltage/sqrt(2). I'm not sure how to get the max voltage. I tried using the secondary voltage as the max voltage, but the answer wasn't right. So, I think the secondary voltage is the AC source. How do I get the max voltage using the secondary voltage? Maybe I'm doing this all wrong? I don't know...any help would be great! Thx in advance! :)
How about trying this? Let the voltage (secondary) as
[tex]v=v_0 e^{jwt}[/tex]
Find the current through the circuit i, using ohms law.
[tex]v_0 e^{jwt} = i (R_b -\frac{j}{wc})[/tex]
where -j/wc is the impedance of the capacitor.
Find the charge of the capacitor q by integrating current i since
i = dq/dt
use q= Cv to find the voltage across the capacitor [tex]v_c[/tex]
therefore, voltage across the body [tex]v_b = v - v_c[/tex]
absolute value of the vb is the max voltage created across the person's body. I am getting this to be about 23 volts using the human body resistance of 1 Mega ohm, causing a current of about 0.023 mA to flow through him. Hopefully it would not kill him. :smile:
Hi there,
First of all, let's redraw the circuit as suggested. We can simplify the secondary of the transformer as a simple AC source with a voltage of 6000 V. The stray capacitance C can be represented as a capacitor in parallel with the body resistance R, which is connected to ground.
Now, we can use the formula V = IZ to find the voltage across the body, where Z is the impedance of the circuit and I is the current flowing through it. We can find the impedance by using the formula Z = 1/(jωC + 1/R), where j is the imaginary unit and ω is the angular frequency (2πf).
So, plugging in the values we have, we get Z = 1/(j2π(60)(10x10^-12) + 1/R) = 1/(j0.012 + 1/R). Now, we need to find the current I. We can use Ohm's law, V = IR, to find the current. Since we know the voltage (6000 V) and the resistance (R), we can solve for I.
Finally, we can use the formula V = IZ to find the voltage across the body, which will give us the maximum voltage. We can then use the formula Vrms = Vmax/sqrt(2) to find the rms voltage across the body.
I hope this helps you understand how to approach this problem. Let me know if you have any further questions. Good luck!
