New Reply
conjuction of planets to Earth, it affects our weight?
Share Thread Thread Tools
Jan21-13, 04:54 PM   #1
Today an interesting question came to my mind...
I have heard that when is a conjunction of planets to Earth, it affects our weight.
If the conjunction occurred at larger planets to Earth - Jupiter, Saturn, Uranus, Neptune (in one line with Earth) - how it affects our weight?
Surely we will use third Newton's law, but beyond that I do not know what to do. Have you got any ideas?
Sorry for my English and thank you very much.
PhysOrg.com
PhysOrg
astronomy news on PhysOrg.com
>> Researchers explain magnetic field misbehavior in solar flares
>> Fragile mega-galaxy is missing link in history of cosmos
>> Researchers reveal model of Sun's magnetic field
Jan21-13, 11:45 PM   #2
Recognitions:
Gold Membership Gold Member
The affect that ANY other celestial body has on our weight on Earth is absolutely miniscule. Even the Moon, whose gravity affects us most barely causes any change.
My rough calculations put Jupiter's acceleration on us at about 2.3x10-7 m/s2. For comparison the Earth's gravity accelerates us at 9.8 m/s2.
Even during conjunction when the planets "line up" with each other, nothing special happens other than their forces add up. But they were already doing this beforehand anyways, just to a slightly lesser amount. Even adding up every outer planet the acceleration would still be less than 3x10-7 m/s2 or so. This is an extremely small amount.
Jan22-13, 04:11 AM   #3
It is clear to me that it will not be much difference, but I want to know how to calculate.
Jan22-13, 04:14 AM   #4
Recognitions:
Quote by Numeriprimi View Post
I use this calculator: http://www.wsanford.com/~wsanford/ca...alculator.html
Put in the mass of one object, say Jupiter, in the first line, and the mass of the 2nd object, say yourself, in the 2nd line. Then put in the distance and hit calculate.
A1 is the acceleration OF THE 1ST OBJECT, caused by the gravity of your 2nd object. It's how much Jupiter accelerates thanks to your gravity.
A2 is the acceleration of the 2nd object, you, caused by the gravity of Jupiter.
Jan22-13, 08:07 AM   #5
Not only the effect is very small; the attraction acts on planet Earth as well as on you. So the net effect is null.
Jan22-13, 05:27 PM   #6
mfb
Mentor
Quote by someGorilla View Post
That is an important point - you don't feel the attraction itself, you only feel a different acceleration for you and for earth, if your distance to the planet is different. As that difference is extremely small relative to the distance of other planets, the influence on your weight reduces by some additional orders of magnitude. I calculated that here, multiply it with your mass to get the weight difference.
Any visible grain of sand will have a greater influence on your weight than any planet.
Jan23-13, 06:58 AM   #7
And even if you want to take into account those tidal effects, the Sun's influence here is much greater than all of the planets' – though still very small.
Jan23-13, 02:14 PM   #8
Recognitions:
Lets consider the sun and moon's effect on your weight, both of which are much closer than Jupiter - and the sun is hugely more massive than Jupiter. And the answer is absolutely negligible - maybe 10-15 milligrams. Changes in barometric pressure, by comparison, can cause you weight to fluctuate by several grams.
Jan26-13, 05:59 AM   #9
And one more question...
We have line Sun - Earth - Jupiter - Saturn - Uranus - Neptune in conjuction. I calculated the value of accelerations the objects for the Earth (how acceleration acting on Earth). Sun vector is the opposite of the others vectors. The resulting acceleration is difference Sun acceleration and others planets acceleration.Value of the resultant acceleration at the Earth is difference of gravity acceleration and my previous calculation.
It is good idea?
Jan26-13, 07:24 AM   #10
Recognitions:
Homework Helper Homework Help
It is good idea?
Yes. That's a method of measuring the perturbations in the Earth's orbit. Of course, that's only measuring the perturbation at some given instant, so it's of limited value. You'd have to do your calculations over and over using different locations of each of the planet to get a very precise trace of the Earth's orbit around the Sun (but it would still follow a basic two-body trajectory with small perturbations simply because the Sun is so big compared to the planets).
On a more practical level, one could measure the net gravitational acceleration of some object between the Earth and Sun, figure out how fast an object would have to be traveling in order to stay in that spot, and then you could place a satellite in that location. (SOHO or ACE, for example.)
Check out LaGrange points.
Jan27-13, 06:45 AM   #11
When the confines of the major part of the gravity of the Earth is left the effects of the Sun, Moon and other planets will be more important.
New Reply
Tags
conjuction, planets, weight
Thread Tools
Similar Threads for: conjuction of planets to Earth, it affects our weight?
Thread Forum Replies
The rotation of the Earth affects the apparent gravitational acceleration at differ Introductory Physics Homework 5
Would the different weight affects the speed of bicycle when coming down slope.? General Physics 18
Finding how weight placed on a ruler affects its oscillation. Introductory Physics Homework 1
Calculating weight & accelleration due to gravity on other planets... Help please! Introductory Physics Homework 2
[SOLVED] Weight of planets General Astronomy 11
