| New Reply |
thickness of graphene |
Share Thread | Thread Tools |
| Jan23-13, 10:07 AM | #1 |
Hello,
I was just wondering what the theoretical thickness of single layer graphene is? Thanks in advance for any feedback. |
| PhysOrg.com |
physics news on PhysOrg.com >> Iron-platinum alloys could be new-generation hard drives >> Promising doped zirconia >> Nanocrystals grow from liquid interface |
| Jan23-13, 10:46 AM | #2 |
A single layer of graphene would be one atom thick, carbon.
| Jan23-13, 10:47 AM | #3 |
Do you know the answer in Angstroms?
| Jan23-13, 10:50 AM | #4 |
1 Angstrom is .0000000001 meters, carbon is 1.54 Angstroms
| Jan23-13, 10:52 AM | #5 |
a carbon atom is not the same thing as graphene. do you know the thickness of graphene in Angstroms?
| Jan23-13, 11:02 AM | #7 |
A carbon atom is not the same thing as graphene but a "sheet" of carbon atoms is. 1 layer thick sheet of graphene is one atom thick. Wrap it in a cylinder, you have a carbon nanotube, put it in a ball you have a buckyball, stack one sheet of graphene on one sheet of graphene you have graphite. I could be wrong, I am no expert.
| Jan23-13, 11:16 AM | #8 |
Hi Greg, thank you for the reply. Your link is an experimental paper. I was hoping for the theoretical value of graphene's thickness, and also the interlayer spacing between graphene sheets in graphite.
| Jan23-13, 11:16 AM | #9 |
There are sp2 bonds between C atoms. It's different from an isolated atom.
| Jan23-13, 11:44 AM | #10 |
AFM depends on Coulombic repulsion to measure thickness. Its hard to tell exactly where is the surface of the layer. Or how do you define the surface of the layer. |
| Jan23-13, 11:49 AM | #11 |
Thanks for the replys. I know there is a widely accepted theoretical value for the thickness, considering all the atom-atom interactions and whatnot. It's just a number. I understand there is a lot to consider when doing AFM scans, but there should be a simple answer to this question theoretically. I knew it once, but have since forgotten.
| Jan23-13, 12:05 PM | #12 |
Also, you can use non-bonding p-orbital electrons of sp2 for rough thickness calculation. Just take the mean radius of their orbital. But then again it will register different in AFM as after bonding with AFM tip, the electronic configuration might change. |
| New Reply |
| Thread Tools | |
Similar Threads for: thickness of graphene
| DOS of graphene | General Physics | 0 | ||
| Building a graphene shell or other graphene hollow structures on the PC | Atomic, Solid State, Comp. Physics | 0 | ||
| Graphene visibility vs. SiO2 thickness | Atomic, Solid State, Comp. Physics | 0 | ||
| two dirac cones are described by two bi-spinors of different chirality | Atomic, Solid State, Comp. Physics | 5 | ||
| DFT and Graphene | Atomic, Solid State, Comp. Physics | 6 | ||
