What is the velocity of a ball thrown from a building before it hits the ground?
  • Thread starter Thread starter racecar12
    Motion
The problem involves a ball thrown from a building at an angle of 51° with an initial speed of 24 m/s from a height of 59 meters. The objective is to determine the speed of the ball just before it impacts the ground, given that it lands 88.5208 meters away from the base of the building.
  • Mixed
  • Participants discuss using both kinematic equations and conservation of energy to find the speed of the ball at impact. Some suggest starting with the vertical motion to determine the time of flight, while others explore the use of energy conservation principles. There are questions about the correctness of the methods used and the results obtained.
Several participants have shared their attempts and calculations, leading to different results for the speed of the ball. There is an ongoing exploration of methods, with some participants expressing uncertainty about their calculations and seeking clarification on the approaches taken. A few have noted that they arrived at the same answer using the conservation of energy method, while others are still reconciling their results.
Participants are working within the constraints of introductory physics concepts, focusing on motion in two dimensions and the application of Newton's laws. There is an acknowledgment of the challenge in reconciling different methods and results, with some expressing a desire for more direct approaches to similar problems.
racecar12
The problem:
A ball is thrown from the top of a building at an angle of 51° to the horizontal with an initial speed of 24m/s. The ball is thrown at a height of 59 meters from the ground and hits the ground at 88.5208 meters from the base of the building.
What is the speed of the ball just before it strikes the ground?
Relevant equations:
x(t) = x(initial) + v(initial)t + 0.5at^2
v(t) = v(initial) + at
My attempt at solution:
I initially wanted to find the time at which the ball hits the ground. Using the x as a function of time equation, I surmised I needed to also solve for v(initial in the x direction) to help me solve for t. Using trig, I defined v(initial in the x direction) as 24cos51. I defined other terms in this equation:
x(t) = 88.5208 meters
v(initial)t = 24cos51(t)
0.5at^2 = -4.9t^2
Using the quadratic formula, t = 1.5 seconds.
I then input 1.5 for t in the equation: v(t) = v(initial) + at. My guess is that if I have the total time the ball travelled, I can determine its velocity at the point of impact.
v(initial) = 24 m/s
a=-9.8 (1.5)
yielding the velocity of the ball to equal -8.9m/s.
I'm not entirely sure I went about solving this problem in a way that is correct. Any suggestions in helping me understand the process of solving this problem are greatly appreciated. Thank you
You want to work with the y direction first to get the time until the ball hits the ground and then use it to find x distance traveled.
Thanks for your advice. I tried it again, this time using the y direction to solve for the total time the ball is in the air. I guess that makes more sense, since the ball starts at 59 meters in the y direction? Therefore it must travel in the negative y direction in the first place?
In doing so, I let 0=y(initial) +v(initial y)t +0.5at^2
y(initial) = 59 meters
v(initial y)t = 24sin51(t)
0.5at^ = -4.9t^2
Quadratic formula yield t = 5.86 seconds.
Using d=vt:
d= 88.5208
v=?
t=5.86 seconds
solve for v. v=-15.1m/s
looks good up to the point of the d=vt you have vx its v iniitial * cos(51) and you need to find vy at 5.86 secs then add them vectorially and then find the length of that vector to get the speed.
Are you required to do it that way? It seems to me that, because they are asking for speed, rather than velocity, it would be much easier to use "conservation of energy".
True, I was just following the OP's line of thought.
There are lots of ways to solve this one but I think I agree that using CoE is the best way.
The ball has PE and KE at the start totaling...
mgh + 0.5mVi2
On landing it has zero PE and KE totaling..
0.5mVf2
Equate
mgh + 0.5mVi2 = 0.5mVf2
Mass cancels. Rearrange to give..
Vf2 = 2gh + Vi2
Vf = SQRT(2gh + Vi2)
or something like that.
Had they asked for the angle whith which it hits the ground then I'd probably calculate the horizontal and vertical components at impact using standard equations of motion.
I think I did it right this time. I went back to this equation:
v(y) = v(initial position in y direction) + at
v(initial position in y direction) = 24sin51
at = -9.8(5.6 sec) = -57.428
v(y) = -38.78m/s
Not required. I'm in intro level physics and we've been taught from 1 and 2 dimension motion up thru Newton's 2nd law. But if there's a more direct approach to solving these types of problems..I can't wait :P
I tried it this way, too and got -24.09m/s.
My two answers don't match up. (The other one being -38.78m/s)
Sorry guys, I'm definitely on the struggle bus on this one.
v(y) = -38.78m/s
I got 41.6 using the CoE way not -24.09 maybe check what you did.
I used this expression in google to get it calculated: sqrt(2*9.8*59 + 24*24)
Set v = [itex]\sqrt{V(x)^2 + V(y)^2}[/itex]
V(x) = V(ox) + at
V(ox) = 24cos51
at = 0 (because no acceleration in the x direction)
Vx^2 = 228.121
V(y) = V(oy) +at
V(oy) = 24sin51
at = -57.428
Vy^2 = 1503.616
Add 'em together and take the square root...41.61m/s
Oh yay we got the same answer :)
Thanks a ton. I'm not very good at these types of problems yet...but I will keep practicing.
Yes, please practice. We need you here at PF to help future students trying to solve these kinds of problems...
racecar12 said:
I tried it this way, too and got -24.09m/s..
It's quite hard for a square root to give a negative answer :-)
I got 41.6m/s
  • · Replies 38 ·
  • · Replies 21 ·
