Register to reply
Why are microwaves reflected by the door?
by Emissive
Tags: door, microwaves, reflected
Share this thread:
Emissive
#1
Jan25-13, 04:45 AM
P: 20
Hi,
I am wondering why microwaves don't escape through the door?
The most common answer seems to be that the wavelength of microwave ovens is about 10-15cm which is much larger than the 1-2mm holes in the grille. But isn't the wavelength of light really just within a vector space of mathematics describing its motion not a description of the actual particle which remains point like? (Well - point like if you could find it in the probability density). We are not really looking at waves in reality as the have no amplitude - making a light wave from front view always look like a dot - and dots would fit through the holes in microwave...wouldn't they?
Phys.Org News Partner Physics news on Phys.org
New approach to form non-equilibrium structures
Nike krypton laser achieves spot in Guinness World Records
Unleashing the power of quantum dot triplets
Bill_K
#2
Jan25-13, 05:54 AM
Sci Advisor
Thanks
Bill_K's Avatar
P: 4,160
Photons are not a universal substitute for classical electromagnetism. Both descriptions are valid and suitable, each in its own restricted domain. Photons are meaningful when the fields are weak and the energies high. This is not the case in a microwave oven, where we still use electric and magnetic fields obeying Maxwell's Equations.
The fields are confined to the interior of a microwave oven by a metallic mesh (size about 1 mm) that covers the walls and door and reflects the microwaves.
Emissive
#3
Jan25-13, 06:26 AM
P: 20
Yes....I guess electromagnetism does explain it but I hoping for the QED interpretation?
Can we imagine a single microwave photon fired at a 1mm hole in the mesh - why would it bounce back?
Vanadium 50
#4
Jan25-13, 01:20 PM
Mentor
Vanadium 50's Avatar
P: 16,115
Do you already understand QED? If not, why do you want an explanation based on something you don't understand?
Emissive
#5
Jan25-13, 02:22 PM
P: 20
Well I wouldn't ask the question if knew the answer? :)
The part I am obviously not understanding is the dimensionallity of the photon. Is there a relationship between wavelength and the chance it will make it through a small opening?
Bill_K
#6
Jan25-13, 02:51 PM
Sci Advisor
Thanks
Bill_K's Avatar
P: 4,160
No, this is the part you are not understanding:
Photons are not a universal substitute for classical electromagnetism. Both descriptions are valid and suitable, each in its own restricted domain. Photons are meaningful when the fields are weak and the energies high. This is NOT THE CASE in a microwave oven, where we still use electric and magnetic fields obeying Maxwell's Equations.
jtbell
#7
Jan25-13, 03:18 PM
Mentor
jtbell's Avatar
P: 11,602
The material that the screen is made of makes a crucial difference here. A cardboard screen with the same size holes wouldn't block the microwaves at all, or only minimally.
sophiecentaur
#8
Jan25-13, 03:50 PM
Sci Advisor
PF Gold
sophiecentaur's Avatar
P: 11,900
It's really unfair of photons not to behave like little bullets, isn't it? Life would be so much simpler if they were - and we wouldn't have to worry about diffraction and all the rest of modern Physics.
This OP is so much the product of really naff Science teaching and the poor level of presentation of Science on the Media. Why don't people appreciate that Science is Really Hard and not very approachable at all?
Emissive
#9
Jan25-13, 04:53 PM
P: 20
Yes - the emisivity of screen within the wavelength concerned certainly has major impact. The is why we wrap our buildings in foil to reflect some of the infra-red radiation and apply low-e coatings to glass to assist with heat loss/gain. Cardboard = no chance (virtually) metal = high chance of reflecting......microwaves in this case.
Ok - I think I worked this out by drawing it. Please correct me if I wrong...
A series of photons approach the screen. Their wavelength is 10x the size of the screen openings and the screen is 30% open. 30% of The photons do pass through the openings (the others hit the screen solid and reflect back) but they pass through every opening and arrive at a point on the side with varying amplitudes which then deconstructively build giving a very limited probability that they will be found there.
When the wavelength is changed to smaller than the opening we get a higher probability amplitude directly in front of the opening and deconstructive ones at holes further away.
Drakkith
#10
Jan25-13, 05:06 PM
Mentor
Drakkith's Avatar
P: 11,501
Quote Quote by Emissive View Post
You are already wrong. Photons do not work like this. Instead, it is an EM wave of a certain energy and frequency that is emitted and propagates towards the screen. When the wave interacts with something, and by that I mean when it actually transfers energy, it will do so in little discrete amounts that we label as photons.
What sophie is trying to get you to understand, and what he has pounded into my head previously, is that you cannot say "a photon approaches the screen" or "what is the size of a photon". A photon is simply not a little particle that would behave in this manner.
sophiecentaur
#11
Jan25-13, 05:14 PM
Sci Advisor
PF Gold
P: 11,900
Quote Quote by Drakkith View Post
"But other fell into good ground, and brought forth fruit, some an hundredfold, some sixtyfold, some thirtyfold."
You have no idea how good that makes me feel!
Drakkith
#12
Jan25-13, 05:25 PM
Mentor
Drakkith's Avatar
P: 11,501
Quote Quote by sophiecentaur View Post
As hard as it was to wrap my head around initially, everything involving light makes a LOT more sense now.
sophiecentaur
#13
Jan25-13, 05:27 PM
Sci Advisor
PF Gold
P: 11,900
One has to chuck out an immense amount of baggage to get there. Most of it came from 'Education', too.
Drakkith
#14
Jan25-13, 05:30 PM
Mentor
Drakkith's Avatar
P: 11,501
Chuck it, burn it, and bury it!
Emissive
#15
Jan25-13, 05:30 PM
P: 20
Interesting.
I would have thought we could say a photon approaches the screen? It is one packet of em energy.
Don't we only ever "see" em waves as photons or discrete packets of energy...We don't get two halfs of a photon showing up. It is only when they transfer energy that they become visible everything in-between is a mathematical model. we could emit one photon at a time with a break - thats a series of photons isn't it?
Drakkith
#16
Jan25-13, 05:40 PM
Mentor
Drakkith's Avatar
P: 11,501
It is in the sense that you measure the energy of the EM wave one packet at a time, with a large time between each packet being delivered to your sensor. However you cannot claim that during transit the photon itself was moving like a little bullet or anything. That simply cannot explain things like interference that are properties of waves.
sophiecentaur
#17
Jan25-13, 05:53 PM
Sci Advisor
PF Gold
P: 11,900
If a photon is detected by a sensor in a certain place in front of the screen then all you can say is that it was detected there. You can say nothing about how (what route) it got there or how big it is/was - except by describing the wave behaviour of the energy and, if you want to, saying that relates to the statistical probability of detecting the photon. The photon is only there when it's being detected. You have no idea how it got there as a photon and if you go looking for a photon somewhere else and detect one, it may affect the probablilty of finding one in the original spot.
This is like trying to decide which slit a photon chose to go through one of the 'two slits' in that well known experiment. If you have a detector to 'catch all the photons' that go through one slit, you get no interference pattern because you have eliminated the possibility of a photon going through that slit.
Emissive
#18
Jan25-13, 06:25 PM
P: 20
Agreed.
But the interference patterns which manifest in locality is maths - a vector space designed to construct and assertian the photons properties but its not actual space in the real world - so I don't see a problem in visualising a photon as point as that is how is shows up (albeit impossible to ever actually locate)......it certainly doesnt move like a bullet as in classical mechanics (because its a wave in it vector space and a bullet is a line in its vector space).
Register to reply
Related Discussions
DSP vs RF/Microwaves and E&M Career Guidance 1
Microwaving has been known to cause anemia General Discussion 9
Microwave oven and cooking General Physics 2
Why do we use microwaves? General Physics 13
Please Please help with Microwaves Introductory Physics Homework 1
