IR Spectra: N-O Nitro group: Why two peaks?
The discussion centers on the infrared (IR) spectra of nitro N-O bonds, which exhibit two peaks at 1550 and 1400 cm-1 due to symmetric and antisymmetric stretching modes. This characteristic is similar to the behavior of CH3 groups, which also show a peak around 1430 cm-1. The inquiry extends to the carbon dioxide stretch, noted as a "doublet" around 2350 cm-1. The question arises regarding the cause of this doublet, as CO2 is linear and typically does not exhibit IR activity for antisymmetric stretching. The discussion highlights the complexities of molecular vibrations and their IR activity, suggesting that further exploration is needed to understand the underlying reasons for the observed peaks in both nitro and carbon dioxide stretches.
nbd
My IR spectra correlation chart for organic chemistry says that the stretch for a nitro N-O bond occurs at "1550 and 1400cm-1" and that it will look like "teeth". Why does N-O have two peaks? The rest of the functional groups on my chart list a range in which a single peak should appear, but why is N-O expected to generate two peaks?
Thanks!
Chemistry news on Phys.org
Thanks!
I suppose symmetric and antisymmetric stretching modes. Note the analogous feature for CH3 groups at around 1430 cm^{-1}.
That makes sense, thank you! In the same vein, I notice that my correlation chart also has the carbon dioxide stretch listed as a "doublet" appearing around 2350 cm-1. Is that for a similar reason as N-O/CH3? In my mind it shouldn't be, because CO2 is not bent and does not have resonance, so the anti-symmetrical stretching would not be IR-active. If that's true, what could be causing the two bands for the carbon dioxide stretch?
Edit: Since this is kind of a new question, I posted it in its own thread here.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
