Projectile Motion Rocket Problem
The discussion revolves around a model rocket launched vertically with an initial speed and constant acceleration until the engine stops. Participants are analyzing the maximum height, time to reach that height, and total time in the air.
  • Mixed
  • Participants explore the calculations for maximum height and ascent time, with some verifying the methods used. There is debate over the approach to calculating the total time in the air, particularly regarding the symmetry of ascent and descent times.
Some participants have confirmed the calculations for parts of the problem, while others have raised concerns about the assumptions made regarding ascent and descent times. There is ongoing clarification regarding the correct approach to determine the total time in the air.
Participants are discussing the implications of different acceleration values during ascent and descent, as well as the need to compute descent time separately rather than assuming symmetry.
TheRedDevil18
Please check my work
A model rocket is launched vertically upwards with an initial speed of 50m/s. It accelerates with a constant upward acceleartion of 2m/s until its engine stop at an altitude of 150m.
2.4.1) What is the maximum height reached by the rocket?
2.4.2) How long after lift-off does the rocket reach maximum height?
2.4.3) How long is the rocket in the air?
equations of motion
2.4.1) To get the max height I first found the final velocity of the rocket before the engine was switched off. I got this to be 55.68m/s. I then used this to find the height reached after the engine was switched off by making it the initial velocity and using the acceleration of 9.8m/s. I got this to be 158.18m. So the max height is 308.18m.
2.4.2) By breaking the problem into two parts(one 150m and the other 158.18m)I got the times to be 2.84s and 5.68s. Adding them up gives me 8.52s to reach its max height.
2.4.3) Multiplied the time by two(going up and coming down) to get 17.04s.
Please could someone check my work, any help would be greatly appreciated
The methods in part 1 and part 2 are correct (not sure about the numbers). The method for part 3 is wrong, the acceleration profiles are different on the way up and down.
Numbers in parts 1 and 2 are correct. Ditto the comment by voko about part 3.
Could you refer to the question number?, on the way up I used 2m/s(given), and when the engines where switched off I used 9.8m/s.
Everyone agrees with what you did for 2.4.1 and 2.4.2. But you cannot simply multiply the ascent time by two to get the total time in the air. It's not symmetric. Compute descent time separately.
Thats what I did in 2.4.2, I broke the problem up and got the times to be 2.48s and 5.48s. Adding them up gave me 8.52s to reach max height. The time going up must equal the time coming down, am I right?, and so that's why I multiplied the time by 2.
Why is that so?
Only if the projectile is symmetric eg. parabola.
Is the final answer 14.77s?, because I think I hit a miss with the acceleration for the second part where I used 2m/s instead of 9.8m/s coming down.
How long does it take for the body to come from the max height down to the ground? What equation gives this time?
It takes 6.26s to hit the ground starting from max height? I used the equation vf = vi+a*t.
Explain how you used the equation. What are vi and vf in your case?
When the planes engines where switched off:
0 = 55.68+(9.8)t
t = 5.68s
For the remaining 150m:
55.68 = 50+9.8t
5.68 = 9.8t
t = 0.58
Adding it up gives you 6.26s.
Okay, is the answer 7.93s to fall from max height?, I just worked it out now.
7.93 s is correct, assuming the max height is indeed 308.18 m.
So the total time in the air is (8.52s to go up + 7.93s to come down) = 16.45s
  • · Replies 53 ·
