Understanding Modulation in 4-20ma Transducers/Transmitters
  • Thread starter Thread starter Adder_Noir
The discussion focuses on the function of modulation in 4-20mA transducers and transmitters. Modulation combines a carrier signal with a data signal to enhance signal transmission while minimizing distortion. Techniques such as amplitude modulation (AM) are employed to boost small signals, which is crucial in applications like neutron monitoring in nuclear power plants. The transducer operates within a 4-20mA range, where the modulator increases the current from 4mA to a maximum of 20mA for effective data transmission.
  • Understanding of 4-20mA signal transmission
  • Familiarity with modulation techniques (AM, FM, PM)
  • Knowledge of transducer functionality
  • Basic principles of signal distortion and amplification
  • Research "4-20mA transducer applications in industrial automation"
  • Learn about "Amplitude Modulation (AM) and its applications"
  • Explore "Phase Modulation (PM) and its advantages in data transmission"
  • Investigate "Signal distortion and methods to minimize it in electronic systems"
Engineers, technicians, and professionals involved in industrial automation, signal processing, and data transmission systems will benefit from this discussion.
Adder_Noir
Dear All,
I have today been introduced to the workings of a 4-20ma transducer/transmitter. My boss described to me the workings of one and he stated that a transducer could be used to modulate the signal coming out of the primary cell.
I understand everything about the transducer but I have one problem with it. I do not know what he means by modulation. What is modulation and why would we use it to modulate the signal coming out of the primary cell :confused:
Thanks in advance :wink:
Modulation is the combining two signals, a carrier signal and a data signal. If you listen to the radio or use a cell phone or watch TV(cable Dish or broadcast doesn't matter) then you are benefitting from the modulation process. There are a couple of reasons to use modulation. For very very small signals you can use amplitude modulation(AM as in AM radio) to help you boost the signal while adding only a small amount of distortion vice directly amplifying the signal which could add a lot of distortion(a nuclear power plant I worked at use this technique to allow for accurate neutron monitoring when the plant was shutdown). You can use modulation to boost a data signal for wireless data transmission (AM, FM, PM(FM stations use PM--phase modulation--because the circuitry is generally simpler)). Again, with radio, cell phones, and TV you take a data signal boost it to very high power levers a and frequencies to send data around the world and out into space. This signal boosting is done in such a manner as to add only minimal amounts of distortion.
Here, a good little page. You might try how stuff works as well.
http://cbdd.wsu.edu/kewlcontent/cdoutput/TR502/page21.htm
So why use it? Low distortion signal boosting, Data transmission over long distances, wireless data transmission, transmission of data at discrete frequencies i.e. the radio spectrum TV Radio and Cell phone companies fight over so much there's also security reason (there's a side product of AM called single side band--SSB which can be used to transmit data much more securely well, FM and PM create sidebands too but are not as useful).
Hope my brief synopsis helped a little.
Good luck.
That is a fantastic explanation mate o:) Cheers a bundle. My boss was telling me how it is used on a transducer which is transmitting data to a drive. It operates on a 4-20ma range. He told me that we only have 4ma entering the transducer but a possible maximum of 20ma leaving the transducer. I am guessing it is the modulator which is responsible for boosting the current up to 20ma going away from the measuring parts of the transducer. Hope that makes sense :-p Thanks very much anyway that helped a lot :approve:
  • · Replies 28 ·
  • · Replies 25 ·
