Solve Fun Problem: Honestly No Idea Where to Start
  • Thread starter Thread starter iRaid
    Fun
The discussion revolves around a problem involving the evaluation of integrals and summations in the context of trigonometric functions, specifically focusing on the expression for \( a_m \) that includes sine functions and their integrals over a specified interval.
  • Participants express confusion about the initial problem statement and the meaning of specific terms. There are discussions about combining equations and evaluating integrals, particularly focusing on cases where \( n = m \) and \( n \neq m \). Some participants suggest using properties of integration to simplify the problem.
The discussion is active, with participants exploring different interpretations of the problem. Some have provided hints about evaluating integrals and using trigonometric identities, while others are questioning how to proceed with proving certain results based on their findings.
Participants are navigating through the complexities of summation notation and integral evaluation, with some expressing uncertainty about how to prove their results. There is an emphasis on understanding the conditions under which certain terms in the summation contribute to the final result.
iRaid
Honestly no idea where to start, I don't even know what this means.
What part of it, exactly, is confusing you? I mean, you say "I don't know what 'this' means," but what does "this" refer to?
Have you considered that you are given an expression for f(x) in the first equation, and then f(x) also appears in the second equation? Seems to naturally suggest a way in which the two equations can be combined, doesn't it?
[tex]a_{m}=\frac{1}{\pi} \int_{-\pi}^\pi \displaystyle\sum_{n=1}^{N} a_{n}\:sin\,nx\:sin\,mx\:dx[/tex]
Is that what you mean? I still have no idea what I would do with that
Yeah, that's what I meant.
Well, for one thing, you can pull the summation sign outside of the integral sign, because there is a property of integration that says the integral of a sum of two or more functions is equal to the sum of the integrals of the individual functions.
So, now you can just focus your attention on evaluating the integral on the inside. Hint: consider two separate cases n = m, and n ≠ m, and try to evaluate the integral for each of those cases.
So you're saying:
[tex]a_{m}=\frac{1}{\pi} \displaystyle\sum_{n=1}^{N} a_{n}\:sin\,nx\: \int_{-\pi}^\pi sin\,mx\:dx[/tex]
iRaid said:
So you're saying:
NO. You can't take sin(nx) outside the integral, because it depends on x.
It seems like the summation notation is tripping you up, so let's consider a stupid trivial example. What if N = 2? Then:
$$a_{m}=\frac{1}{\pi} \int_{-\pi}^\pi \sum_{n=1}^{2} a_{n}\sin(nx)\sin(mx)\,dx$$
This sum only has two terms. One for n = 1 and one for n = 2. So it's not too tedious to expand the sum in full:
$$ a_m = \frac{1}{\pi}\int_{-\pi}^\pi \left[ a_1 \sin(x)\sin(mx) + a_2\sin(2x)\sin(mx)\right]\,dx$$
Now, recall what I already said before (and something you probably already know):
The integral of a sum of functions is equal to the sum of the integrals of those functions
So our expression above becomes:
$$ a_m = \frac{1}{\pi} \left[ a_1 \int_{-\pi}^\pi\sin(x)\sin(mx)\,dx + a_2\int_{-\pi}^\pi\sin(2x)\sin(mx)\,dx\right]$$
Now, if we were to put this BACK in summation notation, we would write it as:
$$a_m = \frac{1}{\pi}\sum_{n=1}^2 a_n\int_{-\pi}^{\pi} \sin(nx)\sin(mx)\,dx$$
Does that makes sense? That's why you can switch the Ʃ and the ∫ around. Because of this property of integration. The same thing holds for "N" terms in the summation.
Sorry it was really late and I wasn't thinking. Yes I see what you're saying.
So: 0 if m≠n and ∏ if m=n. Do I plug these into prove it? I think my problem now is how to "prove" this.
Yeah, you can now just focus on evaluating the integral that is inside the sum for those two cases. For n = m, you're integrating sine squared, which should be doable. For n ≠ m, you have something of the form sin(a)*sin(b), for which trig identities should help.
I did solve for both of those cases already. What do I do with this information now?
Oh, well that part is obvious. What happens to all the terms in your sum if the the integral is 0 when n is not equal to m, and non-zero when n = m?
The standard way is to use trigonometric addition formulas to replace ##\sin (mx) \sin (nx)## by sines/cosines of sums and differences. Alternatively, try using repeated integration by parts.
When the integral is 0, then am would be 0 right?
THINK. The integral is not always 0. The integral is equal to 0 if n is NOT equal to m, and the integral is equal to pi if n = m. We *just* established that. So, which terms in the sum survive and which ones vanish?
