Radii of eqiuipotential surfaces of a charged metal sphere
The discussion focuses on calculating the radii of equipotential surfaces for a charged metal sphere with a radius of 0.29 m and a charge of 0.90 µC. The relevant equation used is V = kQ/r, where k is Coulomb's constant (8.99 x 10^9 NM²/C²). The potential at the surface of the sphere is calculated to be approximately 27931.03 V. To find the radii for the first, tenth, and hundredth equipotential surfaces, the potential values must be adjusted accordingly, but initial attempts at calculating these values were incorrect due to misunderstanding the relationship between the sphere's radius and the equipotential surfaces.
  • Understanding of electrostatics and electric potential
  • Familiarity with Coulomb's law and the constant k (8.99 x 10^9 NM²/C²)
  • Ability to manipulate algebraic equations
  • Knowledge of equipotential surfaces in electrostatics
  • Learn how to calculate electric potential for different charge distributions
  • Study the concept of equipotential surfaces in greater detail
  • Explore the implications of radius in electric potential calculations
  • Investigate the relationship between potential difference and distance in electrostatics
Students studying electrostatics, physics educators, and anyone involved in solving problems related to electric potential and charged objects.
RoosterCancer
A metal sphere of radius r0 = 0.29 m carries a charge Q = 0.90 µC. Equipotential surfaces are to be drawn for 100 V intervals outside the sphere. Determine the radius r of the following equipotentials from the surface.
a) first:___m
b) tenth:___m
c) 100th:_____m
V=kQ/r --> r=kQ/V
I've tried plugging the numbers from the problem in the equation:
r=(8.99 x 10^9 NM^2/C^2)*(0.9 x 10^-6 C)/(100V) = 80.91m
and it's incorrect. I assume the radius of the sphere itself comes into play, but I'm not sure where. Can anyone help?
a) first:___m
b) tenth:___m
c) 100th:_____m
V=kQ/r --> r=kQ/V
What is the potential at the surface of the ball ?
I was able to find the potential of the ball:
V=(9 x10^9NM^2/C^2)*(0.9 x10^-6 C)/0.29m = 27931.03V
and was able to answer part a, by adding 100 V to the ball's potential and using the formula. So, for b, I added 1000 V to the potential and for c I added 10000 V to the potential, but the results were incorrect.
