Volume using Compressibility Factor
The discussion focuses on calculating the volume of 2 kg of ethylene at 270 K and 2500 kPa using the compressibility factor (Z). The user determined Tr as 0.9561 and Pr as 0.496, resulting in Z being approximately 0.75. The equation PV = ZnRT was utilized, but confusion arose regarding the number of moles (n) and the pressure units. Clarifications were provided, emphasizing the need to use the appropriate gas constant R based on the mass in kilograms for accurate volume calculations.
  • Understanding of the Ideal Gas Law and its applications
  • Familiarity with compressibility factor (Z) calculations
  • Knowledge of thermodynamic properties such as temperature (T) and pressure (P)
  • Basic unit conversions, particularly between kPa and atm
  • Study the Ideal Gas Law and its limitations in real gas scenarios
  • Learn about the compressibility factor and its significance in gas calculations
  • Explore the relationship between pressure, volume, and temperature in thermodynamics
  • Review unit conversion techniques, especially for pressure and volume
Students in chemistry or engineering fields, particularly those studying thermodynamics and gas behavior, as well as professionals involved in chemical process design and analysis.
MechE2015
Find the volume of 2 kg of ethylene at 270 K, 2500 kPa using Z
Method to Solve for Z, Using Tr and Pr
PV = ZnRT
Tr = 0.9561
Pr = 0.496
Z found to be approx. 0.75
R given on a table at 0.2964 kJ/kg K
From here, I should have all information needed, I was just confused on units at this point.
V = ZnRT/P
V = (0.75)*(n)*(0.2964 kJ/kg K)*(270 K) / (2500 kPa)
At this point, my main questions are (probably very simple):
What is n, and why? My best guess: (2000 g)/(28 g/mol) = 71.43 mol
What are units for P? My best guess: atm, -> 2500 kPa*24.67 atm/kPa = 61675 atm
Using these numbers, I get Volume to be way too low, corrections needed somewhere. Help appreciated.
PV = ZnRT
Tr = 0.9561
Pr = 0.496
V = ZnRT/P
Take a look at your units. If you're using kj/kg K for R, you should use equation:
PV = mRT, where R is the gas constant for that gas and m is the mass in kilograms. If you use PV = nRuT (Where Ru is the universal gas constant), then you'll need to use the number of moles.
Also, use the fact that 1 Pa*m^3 = 1 J.
36K
