Incremental analysis to solve a circuit with a Zener diode
  • Context: Engineering
  • Thread starter Thread starter pc2-brazil
    Analysis Circuit Diode
The discussion focuses on using incremental analysis to derive an analytical expression for the output voltage (v0) in a Zener diode regulator circuit. Participants apply Kirchhoff's Voltage Law (KVL) to establish relationships between the input voltage (V), output voltage (v0), and Zener voltage (vZ). The challenge lies in accurately estimating the operating point values (VZ and IZ) from a provided graph, which lacks sufficient detail for precise intersection point determination. The dynamic impedance of the Zener diode is estimated to be approximately 12.5Ω based on the characteristics discussed.
  • Understanding of Zener diode characteristics and operation
  • Familiarity with Kirchhoff's Voltage Law (KVL)
  • Basic knowledge of incremental analysis in circuit theory
  • Ability to interpret graphical data related to electrical circuits
  • Study Zener diode voltage regulation techniques in detail
  • Learn how to apply incremental analysis to different circuit configurations
  • Explore methods for estimating dynamic impedance in semiconductor devices
  • Investigate graphical analysis techniques for circuit behavior prediction
Electrical engineering students, circuit designers, and professionals working with voltage regulation and Zener diode applications will benefit from this discussion.
pc2-brazil
The attached figure is an illustration of a crude Zener-diode regulator circuit.
a) Using incremental analysis, estimate from the graph an analytical expression for v0 in terms of V and Δv.
b) Calculate the amount of DC and the amount of AC in the output voltage using the Zener-diode characteristic to find model values.
First I assume that the current iZ in the circuit goes in the direction of the diode's arrow. vZ, the voltage across the diode's terminals, is minus v0. Applying KVL to the circuit in the attached figure, I find that [itex]V+\Delta v = v_0 - i_ZR_1 = -v_Z - i_ZR_1[/itex].
To find an expression for [itex]v_Z[/itex], I first have to find the operating point values [itex]V_Z[/itex] and [itex]I_Z[/itex] in terms of V, considering the case when Δv = 0 (that is, ignoring the small signal). This gives: V = -IZR1 - VZ, or VZ = -IZR - V. So I think I should do a graphical analysis, plotting the line vZ = -iZR1 - V at the given graph to estimate the intersection point VZ, IZ.
But the graph doesn't seem to give enough details for being able to find an intersection point.
Any hints on how to proceed?
Thank you in advance.
I think you can just eyeball the intersection point. Would you estimate it to be -4.5V or -4.4V, or a different value?
Yeah, but you can't assume the reverse voltage curve has infinite slope, otherwise there would be no ac in the output and the problem seems to want a finite ac output.
I agree it's tough to estimate the dynamic impedance of the zener from the graph. Maybe ~ 0.1V/8mA = 12.5Ω.
  • · Replies 45 ·
10K
  • · Replies 20 ·
