Changing Numbers To Prescribed Values Under Special Limitations
  • Context: Undergrad
  • Thread starter Thread starter allo
    Numbers
The discussion focuses on transforming the numerical value of x (1825 + 91/1217) into z (1827 + 2/3) using only the first two terms and basic arithmetic operators. A proposed solution involves the equation ((x) - (x mod 10)) + y = z, although it utilizes modulus. The core inquiry is whether it's possible to manipulate a number's last digit and decimal value solely through the number itself and the desired outcomes. The conversation suggests exploring independent operations on the numerator and denominator as a viable method for achieving the transformation.
  • Understanding of basic arithmetic operations: addition, subtraction, multiplication, and division.
  • Familiarity with fractions and decimal representations.
  • Knowledge of modular arithmetic, specifically modulus operations.
  • Concept of linear combinations in number theory.
  • Research modular arithmetic and its applications in number manipulation.
  • Explore linear combinations and their role in solving equations.
  • Learn about manipulating fractions and decimals in mathematical expressions.
  • Investigate methods for transforming numerical values through arithmetic operations.
Mathematicians, educators, students studying number theory, and anyone interested in numerical transformations and arithmetic operations.
allo
x=1825+91/1217
y=7+2/3
z=1827+2/3
Is there any way to turn x into z only using the first two terms, andor a constant, and the operators ' + ', ' - ', ' * ', ' / '.
I know I can take ((x)-(x mod 10)) + y = z, but this uses a modulus.
... Basically the core of the question is can I change any number's last digit and its decimal value to something I decide by only using the number itself and the desired digit and decimal?
I feel like splitting the numerator and denominator and running independent operations on each might be the way to go.
Mathematics news on Phys.org
1217x = 2221116
3y = 23
As those do not have a common divisor (apart from 1), you can find integers q,r, such that qx+ry=1. That can be written with a long series of "x+x+x+... -y-y-y-..." (or vice versa), of course, so you do not need q and r.
In the same way, you can get 1820. Add y and you are done.
andor a constant
? If you can use the constant z/x, it is easy.
