Photons violate Uncertainty Principle?
The discussion centers on the relationship between photons and the Heisenberg Uncertainty Principle (HUP). It establishes that while the speed of a photon is known (the speed of light), this does not violate the HUP because a well-defined position operator does not exist for photons. Instead, the uncertainty in a photon's momentum, which can be described by its wavelength or frequency, compensates for the knowledge of its speed. The Heisenberg-Robertson uncertainty relation applies to massive particles, indicating that both position and momentum cannot be precisely determined simultaneously.
  • Understanding of quantum mechanics principles
  • Familiarity with the Heisenberg Uncertainty Principle
  • Knowledge of quantum operators, specifically position and momentum operators
  • Basic concepts of photon behavior in quantum physics
  • Study the implications of the Heisenberg-Robertson uncertainty relation in quantum mechanics
  • Explore the concept of position operators for massive particles versus massless particles
  • Investigate the behavior of photons in quantum field theory
  • Learn about wave-particle duality and its effects on measurement in quantum systems
Students and professionals in physics, particularly those focusing on quantum mechanics, quantum field theory, and the behavior of light as a quantum particle.
sarvesh0303
A photon is considered as a quantum particle, right?
However since we know the speed of a photon(speed of light) and hence can predict its position, isn't it violating the Heisenberg Uncertainty Principle?
Where am I going wrong? Is it false to believe that a photon is a quantum particle?
isnt it momentum vs position? so even though we know its speed we might be limited in knowing its momentum (ie wavelength or its frequency) .
It's a bit difficult to talk about a photon's position since there doesn't exist a well-defined position operator for a photon.
For massive particles, there is a position operator, fulfilling the Heisenberg algebra
[tex][\hat{x}_i,\hat{p}_j]=\mathrm{i} \hbar \delta_{ij}.[/tex]
Then for any pure or mixed state the Heisenberg-Robertson uncertainty relation,
[tex]\Delta x_i \Delta x_j \geq \frac{\hbar}{2} \delta_{ij}[/tex]
holds. I tells you that the position and momentum of the particle both are not fully determined but distributed with a finite standard deviation, and the product of these standard deviations cannot be smaller than [itex]\hbar/2[/itex] if you consider position and momentum components in the same direction.
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 23 ·
