Question in regards to the equilibrium law and expressions
The equilibrium reaction A(g) ⇌ 2B(g) + C(g) was analyzed with 1.00 mol of A in a 4.00 L container, resulting in a concentration of C at equilibrium of 0.050 mol/L. The calculations showed that 0.20 mol of C produced 0.40 mol of B and left 0.80 mol of A at equilibrium. The equilibrium constant (Ke) was calculated as 0.0025 mol/L, which is considered a typical value for such reactions. The analysis confirmed that for every x mol of A consumed, 2x mol of B and x mol of C are produced, validating the stoichiometry of the reaction.
  • Understanding of chemical equilibrium concepts
  • Knowledge of stoichiometry in chemical reactions
  • Familiarity with equilibrium constant calculations
  • Basic skills in concentration calculations in molarity
  • Study the derivation and application of the equilibrium constant (Ke) in various reactions
  • Learn about Le Chatelier's principle and its impact on equilibrium
  • Explore advanced equilibrium calculations involving multiple reactions
  • Investigate the use of chemical calculators for equilibrium and concentration problems
Chemistry students, educators, and laboratory technicians who are involved in chemical equilibrium studies and calculations will benefit from this discussion.
walker
Considering the following equilibrium reaction
[tex]A(g) \longleftrightarrow 2B(g) + C(g)[/tex]
And the question:
When 1.00 mol of A is placed in a 4.00 L container at temperature t, the concentration of C at equilibrium is 0.050 mol/L. What is the equilibrium constant for the reaction at temperature t?
Does this mean that for every x mol of A consumed, 2(C) mol of B is produced and 0.050 mol of C is produced.
For example
We get the number of mols of C within the 4.00 L container:
0.050 mol/L C x 4.00 L = 0.20 mol C
Then we use that number to calculate the number of mols produced and consumed at equilibrium for the other gases:
0.20 mol C x 2 mol B/ 1 mol C = 0.20 x 2 mol B = 0.40 mol B
1.00 mol A - [0.20 mol C x 1 mol A / 1 mol C] = 0.80 mol A
Then for the concentrations at equilibrium:
A = 0.80 mol / 4.00 L = 0.20 mol/L
B = 0.40 mol / 4.00 L = 0.10 mol/L
C = 0.20 mol / 4.00 L = 0.050 mol/L
then the equilibrium constant:
Ke = ^2 [C] / [A]
=[0.10]^2 [0.050] / [0.20]
=0.0025 mol/L
0.0025 mol/L seems like a small number for the equilibrium constant which is why I've come here to see if anyone can check the work I've done and point out any mistakes if there are any. I think I might be making a mistake with the 2B, I'm not sure if I'm handling that properly.
Chemistry news on Phys.org
And the question:
ok. Keq = ^2[C] / [A]
[] of A at equilibrium = .250 - x
[] of C at equilibrium = .050 (+x)
[] of B at equilibrium = .100 (+2x) <- since two moles are being created for every one mole of A.
so now, solve [] of A at equilibrium=> .250 - .050 = .200 M
plug it into the equation Keq..
(.100^2)(.050) / (.200) = Keq
Hope this helped. Corrections to my work wil be nice. Thanks.
No. It means that for every x mol of A 2x mol of B and x mol of C is produced, just like you have in you reaction equation.
But the rest seems OK. 0.0025 is nothing unusuall.
Chemical calculators for labs and education
BATE - pH calculations, titration curves, hydrolisis
  • · Replies 0 ·
