Is there water flow against gravity?
The discussion centers on the behavior of water in a closed tube under varying atmospheric pressures. It concludes that when the water level drops below 10.13 meters due to atmospheric pressure of 10130 Pa, atmospheric pressure will not force the water upward against gravity. Instead, the water will remain at a lower level until external forces act upon it. The principle of fluid dynamics, particularly in relation to barometric pressure, is also highlighted, noting that mercury is often used in barometers to minimize fluid column height.
  • Understanding of fluid dynamics principles
  • Knowledge of atmospheric pressure and its effects
  • Familiarity with barometric pressure concepts
  • Basic calculations involving pressure and fluid columns
  • Research the principles of fluid dynamics in closed systems
  • Study the calculations involved in barometric pressure using mercury
  • Explore the effects of vacuum on fluid behavior in tubes
  • Learn about the applications of fluid-filled barometers in measuring pressure
Students and professionals in physics, engineering, and environmental science, particularly those interested in fluid mechanics and pressure systems.
Jpacio
Hi all,
I have been with this issue for some time and think I reached a conclusion but am not sure and was hoping that you guys could help me out with this.
http://spreadzed.com/water_flow/water.png
I was considering the scenario where you have a closed tube like the one you see in the image. Since there is no upper contact with atmosferic pressure, the water will not fall to the plate. It is also known that, from a specific height, the water column weight overcomes atmosferic pressure, thus allowing the water column to fall parcially. I have calculated that, for a specific atmosferic pressure of 10130 Pa, one would need a water column of 10.13 m to start producing vacuum.
Now, the doubt comes in this case: imagine that, for some reason, the water level goes below the 10.13 m (consequently, adding more vacuum to the top of the tube). Will actually atmosferic pressure force the water up against gravity until it reaches the height of 10.13m?
I hope I could explain this properly. Thanks in advance for your help guys :smile:
Yes, and that's exactly the principle behind a fluid-filled barometer (though they use mercury instead of water to reduce the fluid column height and vapor pressure).
  • · Replies 17 ·
  • · Replies 32 ·
13K
