Determine if vector b is a linear combination of vectors a1, a2, a3.
The discussion centers around determining whether vector b is a linear combination of the vectors a1, a2, and a3. Participants explore the implications of row-reducing a coefficient matrix and the interpretation of solutions in the context of linear algebra.
  • One participant describes their method of forming a coefficient matrix with vectors a1, a2, a3 and vector b, and notes that the row-reduced form produces a consistent system with a free variable.
  • Another participant asserts that the solution sheet is incorrect, providing a specific linear combination that equates to vector b.
  • There is a reference to conflicting answers from different sources regarding whether b is a linear combination of the a vectors, with some suggesting that the book's interpretation may be flawed.
  • A later reply discusses a parameterized solution indicating that there are infinitely many solutions for the linear combination, suggesting that the original claim of b not being a linear combination is incorrect.
Participants express disagreement regarding the correctness of the solution sheet, with some asserting that b is indeed a linear combination of the a vectors, while others reference external sources that claim otherwise. The discussion remains unresolved as multiple competing views are presented.
Participants note that the interpretation of the problem may vary, and there are references to different sources that provide conflicting answers. The discussion highlights the complexity of determining linear combinations and the potential for differing interpretations of the problem statement.
roids
Hi guys. I've solved an exercise but the solution sheet says what doesn't make sense to me. Could you please help with this problem?
a1=[1, -2, 0], a2=[0, 1, 2], a3=[5, -6, 8], b=[2, -1, 6].
b is a linear combination when there exist scalars x1, x2, x3 such that x1*a1 + x2*a2 + x3*a3 = b. right?
I put a's in a coefficient matrix and b in the augmented column. [a1 a2 a3 | b]. Row-reduced it produces a consistent system (although I get x3 a free variable - third row all zeroes). But the solution sheet says b is not a linear combination of the a vectors. Where is the catch? Should the RREF have a unique solution?
Thank you.
welcome to pf!
hi roids! welcome to pf! :smile:
show us what you got :confused:
Your solution sheet is wrong: ##2 a_1 + 3 a_2 + 0 a_3 = b##.
Argh: jbunnii beat me to it.
Thanks for the responses fine gentlemen. The book with the solutions is David Lay - Linear Algebra, fourth edition.
Can you please take a look at the same problem someone asked here, where the answerer said that no, b is not a linear combination? https://www.physicsforums.com/showthread.php?t=531233
While you and this someone's from Berkeley document say that b is indeed is a linear combination: http://math.berkeley.edu/~honigska/M54HW01Sols.pdf (page 6, exercise 14)
I attached the original problem and solution from the book. Can it be that the book is asking to not combine the a vectors and just test them one by one with b to see if they separately are linear combinations of b?
[edit] OK, I had to re-read the thread, and actually it is agreeing with us. I'll elaborate below.
No, the question is clearly worded. I'm sure your interpretation was correct. The solution is simply wrong.
To elaborate on what Alchemista said in this thread:
He is saying that for any ##t \in \mathbb{R}##, if we set ##x_1 = 2 - 5t##, ##x_2 = 3 - 4t##, and ##x_3 = t##, then we will have ##x_1 a_1 + x_2 a_2 + x_3 a_3 = b##. Thus, not only is there a solution, there are infinitely many solutions. The solution I mentioned above in post #3 is a special case of this, with ##t = 0##.
The reason for this is that, for any ##t##,
$$-5t a_1 - 4t a_2 + t a_3 = 0$$
Thanks so much jbunnii, you made my day. Love the notation by alchemista.
Have a good day!
22K
