Conceptual physics homework, easy, but understanding
The problem involves a scenario where Bronco Brown attempts bungee jumping, experiencing free fall followed by deceleration due to a bungee cord. The focus is on calculating the change in momentum (∆mv) during the deceleration phase after free fall.
  • Participants discuss the calculation of ∆mv during the 2-second interval of slowing down, with some uncertainty about the mass of Bronco and the implications of the initial momentum calculated during free fall.
Some participants have provided guidance on the calculations involved and have pointed out the need for clarity regarding the mass of Bronco. There is recognition of the relationship between impulse and change in momentum, but no consensus has been reached on the final interpretation of the values discussed.
There is a lack of explicit information regarding Bronco's mass in the initial problem statement, which has led to confusion in the calculations. Additionally, rounding errors in momentum calculations have been noted as a potential source of discrepancy.
knnox
Bronco Brown wants to put Ft =∆mv to
the test and try bungee jumping. Bronco
leaps from a high cliff and experiences
free fall for 3 seconds. Then the bungee
cord begins to stretch, reducing his speed
to zero in 2 seconds. Fortunately, the cord
stretches to its maximum length just short
of the ground below.
∆mv at 3-s free fall is 3000 kg m/s
Then the question asks: ∆mv during the 2-s interval of slowing
down
To my knowledge it is at final velocity leaving it at 3000 kg*m/s
Would it be 1500kg m/s or 3000kg m/s?
I think 3000, but I'm not sure the equation to understand it.
The equation I used gave me 1500 because of the slowing down.
Please help me understand this better.
Welcome to PF knnox!
You are not communicating particularly well, I'm afraid. Nowhere in your problem statement does it actually state what you are supposed to work out. If the problem is to figure out "delta mv during the 2-second interval of slowing down", then that's fine, but I don't know how to check your work, because I don't see a mass stated for Bronco Brown anywhere.
I apologize, it is 100kg, but looking back over this I now realize its just ask delta mv during the 2-s interval which is just 3000kg*m/s which is the same as impulse. Thank you for the response though and sorry for my lack of communication!
You can figure out his speed after free-falling for three seconds using v = v0 - gt, where v0 = 0, since he starts from rest at the beginning of the fall. I get 29.43 m/s for that, which when multiplied by 100 kg gives you a momentum of 2943 kg*m/s. (I guess you rounded up to 3000, but this introduces error). After that, you need to use the impulse-momentum theorem:
FΔt = Δ(mv)​
Here, Δ(mv) will be -2943 m/s, since he starts with 2943 kg*m/s, and ends with 0 kg*m/s, so the change in momentum is 0 - 2943.
Now, given Δ(mv), you can solve for F in Newtons, given that the impulse occurred over a time interval of Δt = 2 seconds.
It sounds like you had it right (up to rounding error) in the first place.
  • · Replies 16 ·
