Velocities of colliding particles (Kinetic and Potential Enegies)
The problem involves two charged beads, C and D, which are initially at rest and separated by a distance of 9.0 mm. The discussion centers around calculating their speeds at the moment of collision using principles of energy conservation, specifically kinetic and potential energy. The beads have different masses and charges, which adds complexity to the analysis.
  • Participants discuss using conservation of energy to relate initial potential energy to final kinetic energy. There is uncertainty about how to treat the final potential energy as the beads approach each other.
Some participants are exploring the implications of potential energy changing as the beads move closer together, while others are questioning the assumptions about the final distance between the beads at collision. There is an ongoing examination of the forces involved and how they affect the calculations.
Participants note the challenge of dealing with undefined potential energy at zero distance and the need to consider the distribution of charge in the beads as they approach each other. There is a recognition that classical mechanics may not fully apply at very small separations.
14dfg
Two 2.0mm diameter beads, C and D, are 9.0mm apart, measured between their centers. Bead C has mass 1.0g and charge 2.5nC . Bead D has mass 1.5g and charge -1.0nC .
K= 9*10^9 Nm^2/C^2
Vinitials =0
mass of C= 1 g
mass of D= 1.5 g
charge of C = 2.5nC
charge of D = -1nC
distance r between them= 9mm
a) If the beads are released from rest, what is the speed vc at the instant the beads collide?
b) If the beads are released from rest, what is the speed vd at the instant the beads collide?
I start by setting up my diagram of the two beads lying on the x-axis. They are 9mm apart from the center, We know initial velocities of both are zero. So I decided to use the conservation of energies formula. Kintial +Uinitial = Kfinal + Ufinal
C: 1/2mvi^2 + (K*C*D)/rinitial = 1/2mvf^2 + (K*C*D)/rfinal
Both Initial Kinetic is zero since they start as rest, as well as Final potential because the distance between them would be zero
So I have (K*C*D)/rinitial = 1/2(mvf^2)
But we have to take into account the kinetic energy of Bead D as well. When doing a similar problem I was told that both Final Kinetic energies must be added. But I would have two unknowns. Both vfinals. I don't know where to go from here. Any hint?
Thanks
Lets see if I understand you:
... I thought the potential changed as 1/d (d is the distance between their centers) ... but 1/0 is undefined.
But surely the beads stop before r=0?
Apart from that:
PE before the motion = PE after the motion + total kinetic energy.
But you also know something else that is conserved.
ok thanks for the reply/ so are you saying that the I should use the distance between the centers as rfinal for the PEfinal?
You can answer that question for yourself by looking at how the Coulomb force works.
For two spheres touching - only the charges immediately next to each other have zero separation - the charges on the rest of the two spheres are further apart. But - classically - the area of the contact is zero so the charge in the contact area is also zero.
If you crunch the numbers you'll find that for r>R (where R is the radius of the bead/sphere), the force acts as if the entire charge is concentrated in the center at r=0. But for r<R, the actual charge distribution matters. Fortunately, two hard beads of charge won't get their centers that close together.
