Proving a Linear Transformation is Onto
The discussion revolves around the conditions under which a linear transformation is considered onto, exploring the relationship between injectivity, surjectivity, and the dimensions of the involved vector spaces. Participants reference the rank-nullity theorem and its implications for linear maps.
  • Some participants propose that a linear map T: V→W is onto if and only if the range of T equals the dimension of W.
  • Others argue that the rank-nullity theorem indicates that if a linear transformation is one-to-one, then it must also be onto, provided the dimensions of the domain and codomain are equal.
  • A participant points out that injectivity and surjectivity are equivalent for linear maps when the dimensions of the domain and codomain are equal, emphasizing the need for this condition.
  • There is a correction regarding the rank-nullity theorem, clarifying that it should state rank(T) + nullity(T) = dim(U) instead of dim(V).
  • Some participants express familiarity with the rank-nullity theorem and its implications for the properties of linear transformations.
  • A participant suggests that a linear map T is an isomorphism if it is either one-to-one or onto, given that the dimensions of the domain and codomain are equal.
Participants generally agree on the relationship between injectivity, surjectivity, and the dimensions of the vector spaces involved, but there are nuances and corrections regarding the application of the rank-nullity theorem and the specific conditions required for equivalence.
Some statements rely on the assumption that the dimensions of the domain and codomain are equal, which is not universally applicable. There are also unresolved points regarding the precise formulation of the rank-nullity theorem as it pertains to the discussion.
BrainHurts
There's this theorem:
A linear map T: V→W is one-to-one iff Ker(T) = 0
I'm wondering if there's an analog for showing that T is onto? If so could you provide a proof?
I'm thinking it has something to do with the rank(T)...
The definition of "onto" is b
"f: U-> V is said to be "onto" V if and only if f(U)= V"
Now, for linear transformations, f(U) is always a subspace of V so f is "onto" V if and only if range(f)= dim(V).
Do you know that "range-nullity" theorem? For linear transformation f:U-> V nullity(f)+ range(f)= dim(V). In particular, if f is one-to-one, so that nullity(f)= 0, we must have range(f)= dim(V) so that f is also "onto" V. Conversely, if f is "onto" V, then it is also one-to-one. That is, a linear transformation is "one-to-one" if and only if it is "onto".
Halls I believe you left something out. A linear map [itex]T:U\rightarrow V[/itex] is injective if and only if it is surjective provided that [itex]dimU = dimV[/itex]. In particular, as you said if [itex]T[/itex] is injective then [itex]nullity(T) = 0[/itex] thus [itex]rank(T) = dim(T(U)) = dimU[/itex] by rank nullity but we then need that [itex]dimU = dimV[/itex] because [itex]dim(T(U)) = dimV,T(U)\subseteq V\Rightarrow T(U) = V[/itex] and similarly for the converse. I believe you had a typo because it should be [itex]rank(T) + nullity(T) = dimU[/itex] as opposed to [itex]dimV[/itex].
Yes, thank you for the correction.
HallsofIvy, just to be sure, you mean that rank(f) because range(f) is a set, and if f is onto then range(f) = V
I am familiar with the rank-nullity theorem. Let f:U-->V is a linear map, rank(f) + nullity(f) = dimU. I think that's what you meant because I am familiar with the statement that T (A linear map) is 1-1 iff nullity(T) = 0
WannabeNewton: You guys both made a similar statement that a linear map T: U-->V is 1-1 iff range(T) = V and that dim(U)=dim(V)
So T is an isomorphism if dim(U)=dim(V) and if T is either 1-1 or onto?
Yes.
Just a little LaTeX tip: Use something like \operatorname or \mathrm to get ##\operatorname{dim}V## instead of ##dim V##.
Thanks broski =D
Yes, not one of my better days is it!
  • · Replies 23 ·
