| New Reply |
Why does superconductors don't radiate? |
Share Thread | Thread Tools |
| Mar13-13, 05:23 AM | #1 |
In ordinary conductors, electrons can lose energy by two mechanisms.
First, by electron scattering on atoms of the lattice bulk, thus transferring energy to the bulk and increasing the bulk's temperature. This is the main contribution to the conductor resistance. But there is also the second mechanism; by radiating electromagnetic radiation due to electron acceleration. In a closed conducting circle electrons move circularly, and therefore have some acceleration, and therefore radiate. This is a relatively small contribution to the total rate of energy loss, but is not zero. Now superconductors! In superconductors, the bulk has an energy gap, so electrons (or more precisely, Cooper pairs) cannot transfer an arbitrarily small energy to the bulk. This prevents the first mechanism of loosing electron energy. But I don't see that anything prevents the second mechanism. In superconductors, electrons should still lose energy by producing electromagnetic radiation. As far as I know, there is no energy gap for the superconducting electrons themselves (the gap exists only for the bulk). So why don't they radiate? Or perhaps they do? |
| Mar13-13, 05:38 AM | #2 |
Recognitions:
a)Charges radiate when accelerated. Cooper pairs at constant velocity won't radiate.
b) An electron in a SC doing a radiative transition would break the pair. This leads to the same consequences as with scattering. |
| Mar13-13, 05:50 AM | #3 |
| Mar13-13, 06:31 AM | #4 |
In a ring with a circulating super-current, the circulating current is a collective motion of all of the Cooper pairs, so it is constant in time. You could equally well ask why the rotating charge of an electron with spin 1/2 does not radiate.
| Mar13-13, 06:41 AM | #5 |
Recognitions:
| Mar13-13, 08:56 AM | #6 |
Recognitions:
I'm not sure this is relevant, but when the electromagnetic field is coupled to a superconductor there is the Meissner effect in which the photon acquires mass.
| Mar13-13, 09:09 AM | #7 |
| Mar13-13, 09:12 AM | #8 |
| Mar13-13, 09:15 AM | #9 |
| Mar13-13, 09:16 AM | #10 |
Mentor
The only means of creating a sustained supercurrent is in a closed loop of superconductor. The current is NOT created by applying an external electric field. Rather, it is via magnetic induction, which creates a current of opposing magnetic field. Zz. |
| Mar13-13, 09:22 AM | #11 |
| Mar13-13, 09:37 AM | #12 |
It seems that atyy is right. For example, Wilczek in
http://www.google.hr/url?q=http://ww...8XQWtN55dE2m6g says: " An unusual but valid way of speaking about the phenomenon of superconductivity is to say that within a superconductor the photon acquires a mass. The Meissner effect follows from this. Indeed, to say that the photon acquires a mass is to say that the electromagnetic field becomes a massive field. Because the energetic cost of supporting massive fields over an extended volume is prohibitive, a supercon- ducting material finds ways to expel magnetic fields." Or let me put it in my own words (from a point of view of someone who is more familiar with particle physics than with solid state physics): The Universe as a whole is also in a (partially) superconducting state, in the sense that acceleration of electrons does not produce W and Z radiation, which is because those fields acquire an effective mass due to the Higgs mechanism. |
| Mar13-13, 10:25 AM | #13 |
Recognitions:
Of BEHGHK, Higgs, I think, was the one directly inspired by Anderson's work on superconductivity. Anderson had explicitly suggested the connection.
| Mar13-13, 10:54 AM | #14 |
Recognitions:
I don't think that the Higgs mechanism is relevant here. It only affects the longitudinal component of the electric field but not the transversal one. Hoever, a moving charge will emit transversally polarized light.
| Mar13-13, 01:21 PM | #15 |
You are probably thinking of the analog of these loops with respect to synchrotron accelerators. In order to calculate the synchrotron acceleration in a real synchrotron (one with a vacuum in the ring), one would have to know the average velocity of the charge carriers. The books only tell us how thermal energy causes the current to diminish. I am getting the following information on superconductors from Introduction to Solid State Physics 7th ed. by Charles Kittel, pages 356-368. A ring of superconducting wire generates a magnetic field that causes a nonzero flux through the area inside the ring. According to quantum mechanics, the flux through the ring is quantized in steps of "hc/2e" where h is Planck's constant, c is speed of light and e is the charge of a single electron. Of course, 2 e is the charge of a Cooper pair. If the flux can only change in finite steps, the magnetic potential energy can only change in quantized steps. The exact timing of the change would be random, but the average time between jumps would be fixed by what processes release energy. A fluxoid could change either by emitting energy or possibly absorbing energy. The book mentions thermal energy. It claims that for a typical semiconductor and a typical loop the average time of about 10^10^7 seconds. The universe will be long dead by then. The book doesn't do the calculation for your process. It is theoretically possible that a fluxoid could change by emission of "synchrotron radiation" caused by the Cooper pair radiating in a circle. I hypothesize that it would take a similar time. If I was interested enough to do the problem, here is how I would start. Calculate the electric current density in the wire. That would be total current divided by cross sectional area of wire. Look up the number density of free carriers in your wire. In most superconductors, that would merely be the density of conduction-electrons. There are tables for that sort of thing. Divide by the charge density of the carriers in the wire. This will be the tangential velocity (v) of Cooper pairs in the loop. The acceleration would be given by the centripetal law (a=v^2/r). Look up the power relations for synchrotron radiation. You could use the formula for real synchrotron. Determine the circumference of the wire, or the radius of the wire. Substitute the velocity of the charge carrier into the power function and radius of the wire into the synchrotron formula. You will see on average how much average power would be emitted by the loop. Then use the equations for quantization of magnetic flux to determine how long it would take for the loop to change even by one fluxoid. I think it would be a long time. However, I would love to be proven wrong !-) |
| Mar13-13, 05:58 PM | #16 |
The answer to this question is much more simple then it looks. Normal ring currents also don't radiate. The acceleration of charges in the form of an electrical ring current is not enough to produce radiation.
There is a thought experiment somewhere, where you start with a spinning disk. At first it has two charges on it and radiates and supposedly with every charge that you add and distribute evenly on the perimeter, the radiation becomes more multi pole like and gets smaller and smaller. In the continuous limit the radiation goes to zero. The cooper pair are in a macroscopic coherent state. There are no charge fluctuations, so the spinning ring does not produce any [itex]\frac{\mathrm{d}E}{\mathrm{d}t}[/itex]. Because it doesn't produce a time varying electric field it cannot radiate (actually even the magnetic field shows no time variance). Radiation caused by accelerating charges is actually a pretty difficult problem... |
| Mar13-13, 06:41 PM | #17 |
You are saying that the power of the emission is zero for all practical purposes. I agree with you. However, "zero for all practical purposes" isn't the "mathematical zero". If the carriers are traveling in a circle, then the carriers are accelerating. The centripetal acceleration is very, very small but still not zero. The laws of electrodynamics and relativity don't care that they are in a conductor. The OP was asking a hypothetical question concerning the extreme limits of possible measurement. He wasn't asking about flat impossibility. He was pointing out that there has to be a small amount of emission for any loop of wire. If the charge is accelerating but not in the ground state of motion, then the charge should hypothetically emit radiation. If the circulating current is large, then the fluxoid of the superconducting loop is large. The carriers won't be in a ground state. So strictly speaking, they must radiate. I think the answer is that the power dissipated by the carriers in a ring current emit radiation so slowly that it is practically impossible to detect it using current technology and technology long in the future. The calculations for thermal emission from the loop are something like one fluxoid every 10 to the power of 1,000,000 years. From a strict mathematical point of view, it isn't zero. However, it is zero for all practical purposes. |
| New Reply |
| Thread Tools | |
Similar Threads for: Why does superconductors don't radiate?
| Will they radiate or not? | Classical Physics | 4 | ||
| Does antenna radiate DC? | Electrical Engineering | 10 | ||
| Will it radiate? | Special & General Relativity | 3 | ||
| To radiate or not to radiate | Special & General Relativity | 63 | ||
| What do we radiate? | General Physics | 25 | ||
