Question about Helium at absolute zero
The discussion revolves around the behavior of helium at absolute zero, particularly focusing on its atomic vibrations, the conditions under which it can solidify, and the implications of applying pressure. Participants explore theoretical and empirical aspects of helium's state at low temperatures, including its unique properties as a liquid and solid.
  • Some participants assert that helium cannot freeze at absolute zero due to minimal atomic vibrations, while others clarify that solids still exhibit vibrations.
  • There is a question regarding the amount of pressure required to solidify liquid helium, with references to specific pressures (25-30 Atmospheres) needed for helium-3 and helium-4.
  • One participant suggests that the discussion about helium at absolute zero may be rendered meaningless without proper context, particularly regarding the definitions of states at zero volume.
  • Some participants propose that the minimum vibration of helium at absolute zero prevents it from solidifying unless subjected to significant pressure.
  • A later reply introduces the concept of minimal entropy at near absolute zero and discusses the formation of quantum condensates in superfluid helium under certain conditions.
  • There is a mention of analogous effects in metals, where electron behavior changes with density at low temperatures.
Participants express differing views on the behavior of helium at absolute zero, particularly regarding its ability to solidify and the role of pressure. There is no consensus on the implications of pressure on atomic vibrations or the definitions surrounding absolute zero.
The discussion includes assumptions about the definitions of states at absolute zero and the conditions under which helium behaves as a solid or liquid. Participants reference empirical properties without resolving the complexities involved.
kjamha
At absolute zero, I understand that atoms have a minimum vibration (the atoms are not completely still). Because of this minimal vibration, He atoms can not freeze at absolute zero. But if enough pressure is applied, the liquid then becomes a solid. Does the pressure eliminate or reduce the minimum vibration? Is solid He colder than absolute zero?
Chemistry news on Phys.org
Liquid helium is not at absolute zero.
Nothing is... it is the empirical limit of zero volume on a T-V graph.
Solids still have vibration.
Define "enough" pressure - how much would be "enough" to solidify liquid helium?
Bear in mind that liquid helium II is already a Bose-Einstein condensate.
I think you need to bear in mind that simple models tend to break down in extreme situations.
Nothing is...
Right. I should have said "theoretically speaking" regarding helium at absolute zero.
do you mean molecules/atoms?
Also, if helium were under adequate pressure, I assumed that it could exist as a solid and I was wondering about the atoms minimum vibration under these conditions. Is the assumption wrong?
Perhaps you should have said - "a perfect ideal gas, in the classical regime, at absolute zero" rather than specifying "helium". But all you've done is render the question meaningless as that would mean the state of zero volume.
Liquid helium 3 and 4 does solidify under high pressures. 25-30Atmospheres.
You can go look up the properties.
I am referring specifically to helium. Helium is the one exception that will not freeze at absolute zero.
The minimum amount of vibration of helium at absolute zero will not let helium turn into a solid (freeze), unless under a great amount of pressure.
I am not interested in how much pressure is required to squeeze helium into a solid. Instead, I wanted to know if this pressure reduces the amount of vibration for the helium.
The state of a substance at (or near) absolute zero is not so much a question of vibrations but of minimal entropy. In superfluid He, the atoms form a quantum condensate, however at higher pressures a solid is energetically favoured.
Analogous effects occur in metals, even at zero temperature: At normal metallic densities, the electrons in a metal behave like a gas of electrons, while at very low densities, they form a solid structure, the so-called Wigner lattice.
  • · Replies 35 ·
  • · Replies 23 ·
11K
25K
