Find the area bounded by y^2=x and y=x=2
  • Context: Undergrad
  • Thread starter Thread starter hytuoc
    Area Bounded
The area bounded by the curves defined by the equations y² = x and y = x = 2 can be determined by first identifying the correct equations. The discussion clarifies that y = x = 2 is likely a misinterpretation and should be y = x - 2 or y - x = 2. To find the area, one must calculate the area under the parabola y² = x and then subtract the area under the line defined by the corrected equation. The intersection points of these curves are found by solving the equation y² - y - 2 = 0.
  • Understanding of parabolic equations, specifically y² = x.
  • Knowledge of linear equations and their graphical representation.
  • Ability to solve quadratic equations.
  • Familiarity with calculating areas under curves.
  • Learn how to solve quadratic equations using the quadratic formula.
  • Study the method for calculating the area under a curve using integration.
  • Explore graphical methods for finding intersections of curves.
  • Investigate the properties of parabolas and their applications in area calculations.
Students studying calculus, mathematics educators, and anyone interested in understanding area calculations between curves in analytical geometry.
hytuoc
How do I do this problem below? Plz guide me step by step or a least show me the correct bounds so I can learn...thanks
***Find the area bounded by y^2=x and y=x=2
Thanks so much
Thanks so much
You could always find the are enclosed by the second equation, then you could find the area between the first eqn and the x axis, then you could subract the second area from the first.
First rule: check the problem carefully- doubt that the question actually says "y= x= 2". It might well be y= x-2 or y-x= 2 which are very different.
Second rule: draw a picture. y2= x is a parabola (with x-axis as axis),
y= x- 2, which can be written as x= y+2, is a line which crosses the parabola when
x= y2= y+ 2: solve the equation y2- y- 2= 0.
(or, if you mean y-x= 2, x= y-2 so x= y2= y- 2.)
  • · Replies 17 ·
