Calculating Rx for a 0 Reading on Voltmeter - Ohm's and Kirchhoff's Laws
  • Thread starter Thread starter lendav_rott
    Voltmeter
The original poster is trying to determine the value of Rx in relation to resistors R1, R2, and R3 so that a voltmeter reads 0. The discussion involves concepts from Ohm's law and Kirchhoff's laws.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore current distribution using Kirchhoff's current law and question how current flows in the circuit. There are discussions about voltage dividers and the conditions under which the voltmeter would show 0.
Some participants have offered insights into voltage division and the relationship between the voltages across the resistors. There is an acknowledgment of the need for careful terminology in discussing electrical concepts, and the conversation reflects a mix of interpretations and clarifications.
There is a mention of potential language barriers affecting the clarity of communication, particularly regarding terminology related to voltage and current.
lendav_rott
In the diagram, attached to this post, what is the value of Rx in relation to R1 R2 and R3 so that the voltmeter would show 0?
Ohm's law and Kirchhoff's laws I suppose.
I have thought about this thing for too much now, and I have no idea what is going on. My 1st attempt was to use current distribution according to Kirchhoff's current law and see where that takes me, BUT I don't understand how the current flows.
Is it
ABC, ABDC and ADC, ADBC or does it stay looping ABDA(although I doubt it does)?
Think about it as two voltage dividers that you want to divide by equal amounts.
Ok so for the voltmeter to show 0, the potential difference between B and D is 0, and the potential difference is 0 when the same voltage flows through either side?
So if V1 is my ingoing voltage and Va and Vb as the 2 equal portions so that their sum would give V1 then
Va = V1*R2/R1+R2
Vb = V1*Rx/Rx+R3
and some simple maths here and there Rx = R2*R3/R1
Thanks for mentioning the voltage division thing, that made it all plain and simple all of a sudden :D amazing how difficultly simple some things can be. So this is just a matter of interpretation of the Ohm's law. Guess that answers my original question of how the current flows too now hmm :)
yep (except that voltage doesn't "flow" --- current does that; sloppy terminology leads to sloppy thinking)
Va = V1*R2/R1+R2
Vb = V1*Rx/Rx+R3
I didn't check your math but you certainly have the right idea.
Exactly. We all have those moments.
Not "interpretation", "application". Again, sloppy terminology ...
yep
Okay I will try to refrain from making these stupid errors.
How would it be acceptable then?
"the potential difference is 0 when the same voltage is present on either side"?
Or how can I say it?
I am only asking because English is not my 1st language.
  • · Replies 18 ·
13K
