If Ʃa_n converges, with a_n > 0, then Ʃ(a_n)^2 always converges
  • Thread starter Thread starter DotKite
The discussion revolves around the convergence of the series Ʃa_n, where a_n > 0, and the implications for the series Ʃ(a_n)^2. Participants are exploring the relationship between these two series and the conditions under which the convergence of one implies the convergence of the other.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of the ratio test and comparison test to analyze the convergence of Ʃ(a_n)^2 based on the convergence of Ʃa_n. There is uncertainty regarding the assumption that 0 < a_n < 1, and whether this can be justified given that a_n converges to 0.
The discussion is active, with participants providing hints and engaging in reasoning about the implications of the convergence of Ʃa_n. Some guidance has been offered regarding the use of the comparison test, but questions remain about the validity of certain assumptions.
Participants are considering the implications of the condition a_n > 0 and its relationship to the convergence of the series. There is a focus on the behavior of a_n as it approaches 0 and the implications for its bounds.
DotKite
if Ʃa_n converges, with a_n > 0, then Ʃ(a_n)^2 always converges
n/a
I am at a complete loss. I have tried using partial sums, cauchy criterion, and I tried using ratio test which seems to work but I am not sure.
Since Ʃa_n converges then by ratio test
lim n->∞ a_n+1 / a_n < 1
Now we apply ratio test to Ʃ(a_n)^2
lim n→∞ (a_n+1)^2 / (a_n)^2 = (lim n→∞ a_n+1 / a_n)^2 < 1^2 = 1
Thus by ratio test Ʃ(a_n)^2 converges.
This working did not utilize the condition a_n > 0, so it seems suspect to me.
Hint: if ##0 < a_n < 1##, then ##a_n^2 < a_n##.
Ok so you use comparison test right? since (a_n)^2 < a_n and a_n converges then (a_n)^2 converges as well, but is it correct to assume 0<a_n<1? Can you assume that because since
Ʃa_n converges that implies a_n → 0 and for some n≥N a_n is in (0,1)?
Yes, that's right, or putting it more precisely, there exists an ##N## such that ##a_n \in (0,1)## for all ##n \geq N##. And then use the comparison test.
thanks a bunch J
  • · Replies 34 ·
