What is the Best Time to Split Cells?
  • Thread starter Thread starter Goodie
The discussion revolves around the optimal timing and conditions for splitting cells in culture, particularly focusing on the mid log phase, confluence levels, and their implications for transfection and cell growth. Participants explore various factors influencing these decisions, including cell type and growth conditions.
  • Some participants suggest that splitting cells at mid log phase is ideal for continued division, while others argue that cells at 100% confluence have stopped dividing due to space limitations.
  • There is a discussion about the significance of confluence percentages, with some proposing that 80-90% confluence indicates mid log phase, while 100% confluence is considered end log phase.
  • Participants mention that the split ratio (e.g., 1/2 to 1/20) may depend on the specific cell type and the desired number of cells, with different cell lines exhibiting varying responses to splitting.
  • Some express skepticism about the necessity of splitting at mid log phase, arguing that trypsin treatment halts cell division regardless of the growth phase.
  • There is a suggestion that for cells in suspension, splitting at mid log phase is more critical than for adherent cells, which may stop growing due to trypsin treatment regardless of the phase.
  • Participants inquire about the rationale behind choosing specific split ratios, linking it to the number of cells needed and the growth requirements of different cell types.
Participants do not reach a consensus on the best practices for splitting cells, with multiple competing views on the importance of mid log phase, confluence levels, and the effects of trypsin treatment. The discussion remains unresolved regarding the optimal conditions for cell splitting.
Participants express uncertainty about the definitions of confluence and mid log phase, as well as the implications of different splitting strategies based on cell type. The discussion highlights the variability in cell behavior and growth requirements.
Goodie
Should I always split my cells at their mid log phase? Or does it only matter at transfection? How do I know that my cells are in the mid log phase? How do i know that my cells are 80-100% confluence? Is this 80-100% a rough estimation or accurately done?
Thanks.
Biology news on Phys.org
Its all rough estimates, 80-100% means usually a full dish of cells, depending on the transfection methods and the cell lines used the general idea is that cells need to be around 50% confluent and preferably not in colonies for optimal transfection. I usually split my cells 24 hours before transfection.
So when my flask is confluent then my cells are at the mid log phase? The split ratio is usually 1/2 to 1/20. What decides which factor we should use? :rolleyes:
nope, the general idea about splitting at mid log phase is that the cells keep dividing while if you thake em at end log phase (confluent dish) the cells have stopped because they ran out of space and have to re-enter the cell cycle which presumably takes a long time (depending on cell type). So its faster if you need many cells. Personally I think this is bullocks because treating the cells with trypsin will also stop them. This then only holds true for cells in suspension and there they don't run out of space but rather out of nutrients.
If you want to know the factor I need to know the cell type... a full dish of primary human fibroblasts will stop cycling if you split them more than 1/4 while transformen human embryonic kindey cells can go 1/15 without any problem.
So does it mean that a 80-90% confluence is most probably at mid log phase and 100% confluent is at end log phase?
What do you mean?
For example why one splits a flask into two new flasks (split ratio 1/2) instead of 4 new flasks (1/4) ? Is that the amount of cells one needs that also decide it? :rolleyes:
Thanks.
no at 80-90% most of the cells have reached confluency and some are still dividing so if the whole dish is viewed this would be near end log phase. at 100% all the cells have stopped
at 50% confluency most of the cells will still be growing so since most of the cells are now in log phase the plate can be regarded as being in log phase. mid log phase is when most cells on the plate are dividing (so at 50% or so) but note that the individual cells do not have to grow faster. Your looking at growth of the population as a whole, not the single cells
Goodie said:
What do you mean?
Basically that for cells in suspension it does matter if you split them at mid log because they will keep growing but for cells that grow attached to the plate it doesn't matter at which stage you split them because they will arrest anyway due to the trypsin treatment. (your original question was: Should I always split my cells at their mid log phase?)
Thanks.
Not just that, some cells need to be in close contact with their neighbours to be able to grow, they depend on growthfactors of surrounding cells that are released in the medium. If you dilute them too much they will just stop.
