What Forces Act on a Car Negotiating a Bend at Constant Speed?
  • Thread starter Thread starter timarli
    Bend Car Forces
The discussion revolves around the forces acting on a vehicle negotiating a bend at constant speed, focusing on concepts of centripetal force, friction, and the role of gravity on an inclined surface.
  • Exploratory, Conceptual clarification, Assumption checking, Mixed
  • Participants explore the relationship between centripetal force and friction, questioning the validity of equations related to normal force and static friction. They discuss the implications of different assumptions and interpretations of forces acting on the vehicle.
The discussion is active, with participants providing insights and questioning each other's reasoning. Some guidance has been offered regarding the interpretation of forces and the use of different coordinate systems, but no consensus has been reached on the correct formulation of the equations.
Participants express confusion over varying sources and interpretations of the equations, particularly regarding the signs and components of forces involved. There is an acknowledgment of the complexity of the problem and the need for further clarification on certain assumptions.
timarli
Hi,
I am confused a little bit with the forces acting on a vehicle when it's negotiating a bend, at constant speed.
Please click the link to see my sketch.
On the plan view I see that it's moving with constant speed, along a circular route. That means there is unbalanced force causing central acceleration. F=mv2/R.
Then going to the section I showed the forces acting on the vehicle. Gravity, Normal Force and the friction. These should be the forces causing this F (central acceleration).
Equation 1, 2, 3 and 4 are the ones I have but somehow I couldn't get to the 5 which is given as the overall formula for such movements.
Can you please tell me what I am doing wrong? Thanks in advance.
timarli said:
Hi,
Equation #2 is the problem.
[itex]\displaystyle F_\text{f}=\mu N[/itex]
In your equation #5, shouldn't there be a minus sign in the denominator if [itex]\displaystyle \ \frac{v^2}{R}>g\tan(\theta)\ ?[/itex]
Thanks SammyS.
Eq#2: if N=m.g.cos0 is not true then I'm more confused...But equation#5. I hope you are right. That's the main issue that confuses me; every source gives a different formula, some of them take the directions different, some of them find the signs of cos & sin different. I really don't understand how this thing can have so many variations...One other question; instead of breaking down everything along major x and y-axis es, can I use the inclined surface as my x and the perpendicular as y?
Fc.cos0=Ff+m.g.sin0 ?
timarli said:
Thanks SammyS.
Yes, you can do that.
Added in Edit:
The perpendicular component then gives:
FC sin(θ) + N = mg cos(θ) .
If N=m.g.cosθ then there is no net force perpendicular to the plane. But Fc has a component in that direction, so this cannot be true.
Also, it is not true in general that the force of static friction is given by Fsf = Nμs. That's the limiting case, i.e. |Fsf| ≤ Nμs. For the max speed, Fsf = Nμs, assuming Fsf is measured down the plane. But, measuring it the same way, there may also be a minimum speed given by Fsf = -Nμs.
Using your sketch showing the vehicle on the inclined roadway, I get the following.
Of course, the magnitude of the force of friction is given by
[itex]\displaystyle <br /> F_\text{f}=\mu N[/itex]​
The sum of the forces in the vertical direction is:
[itex]\displaystyle <br /> N\cos(\theta)-F_\text{f}\sin(\theta)-mg=0[/itex]
Therefore,
[itex]\displaystyle N\cos(\theta)-\mu N\sin(\theta)-mg=0[/itex]​
Solve that for N.
[itex]\displaystyle <br /> N\sin(\theta)+F_\text{f}\cos(\theta)=ma_c\,, \[/itex] where aC is the centripetal acceleration.
That becomes [itex]\displaystyle \ \ N\sin(\theta)+\mu N\cos(\theta)=ma_c\ .[/itex]​
I realize that I didn't use the centripetal force, FC explicitly. I find it's clearer for me to do it this way.
haruspex makes a good point regarding μN being the maximum possible frictional force.
Therefore, your results are for the maximum speed possible, our equivalently they're for the minimum value of μ needed to negotiate the curve under the specified conditions .
I couldn't understand the first part. To me, Fc is a resultant force, it's not a force acting on the body so I always thought I can not write it as "m.g.cos0-Fc.sin0 = N". I don't know why because the same thing makes sense to me for the other axis ie. "Fc.cos0=Ff+m.g.sin0". :S
Looks like I am misinterpreting some fundamental rules.
I got it! I understand what you mean now. When I use the secondary axis es (along the slope and perpendicular) and think of the position of the object 2 seconds later I can see the acceleration along both axis es.
Thank you very much SammyS and haruspex! I understand what you are saying about the friction and I will look at the minimum speed version tomorrow - to make sure I understood :) and probably post again if I can't figure that out.
You were really helpful...thanks again.
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 26 ·
